Activity › Forums › Adobe After Effects › COW Tutorials: After Effects 3D Compositing
Posted by Kathlyn Lindeboom on November 16, 2005 at 1:26 am
&page=/articles/kramer_andrew/3dcompositing/index.html”>3D Compositing In this video tutorial, Andrew Kramer demonstrates 3D Compositing in After Effects 6.5. You’ll create 3D Camera Depth of Field, Move Layers in 3D Space and Animate the Camera, adding Effects.
Click on the link above to watch Andrew’s video tutorial.
Kathlyn Lindeboom
Creativecow.netAndrew Kramer replied 20 years, 10 months ago 8 Members · 10 Replies -
Unique
November 16, 2005 at 2:26 pmwow this is a realy helpfull tutorial..
thanks a lot[IMG]https://i13.photobucket.com/albums/a275/livingoninlines/signatures/signature.jpg[/IMG]
Andrew Kramer
November 16, 2005 at 7:38 pmCool!
I’m glad you guys like it.
If something wasn’t covered or overlooked please let me know. I’d be happy to try and help.Cheers,
Andrew -
Jetle25
November 17, 2005 at 6:41 amGreat Tutorial. Touches on many simple things that happen in 3D. Though I do have one question. What resolution were your png files? I still consider myself a novice with after effects and I’m just building on what i know. Would those files you had to push back in Z space and scale up have to be a pretty high resolution to avoid pixelation? Thanks
Kenny101
November 17, 2005 at 6:52 amto answer jetle25’s question…in the included source footage, the PNG’s were 760×560 resolution..they seemed quite high quality to begin with…and its logical that you would need HQ images for them to scale w/o pixelation
Andrew Kramer
November 17, 2005 at 7:35 amGood point guys,
Although I have learned a cool thing. High quality is good but perceptual High Quality is better. Even though the files are pushed into Z space the camera still shows them at actual size, so perceptually there isn’t much differnce in quality since they are only be shown at actual size. Now getting to close to the wall can be tricky but AE does a nice job of scaling things when zoomed.
Now as for zooming around if you get to close you will run in to some problems. That is why Depth of Field is a good thing. When object get to close they go out of focus so that you can’t tell it low res.
BTW Contact Info can be found at http://www.VideoCopilot.net
Andrew
Robert Morris
November 18, 2005 at 7:17 amAlso, when you zoom into something like at the end of the tutorial, you can turn on motion blur for the layer and that REALLY helps to obscure any pixelization.
