Activity Forums Panasonic Cameras Cow Magazine Article on the 500
  • Cow Magazine Article on the 500
    Posted by Steven Ludlow on June 5, 2008 at 5:27 am
    After reading the article on the HPX500 in my newly arrived issue of Creative Cow Magazine, I am left wondering if there is a compelling reason to still purchase the HVX200A.
    We are in process of moving from DVCAM to P2 and were looking at fielding a mix of HVX200As and HPX500s. Other than size, IS there a good reason to have both — or if one can field all 500s, would you?
    Thanks in advance for the feedback –
    Steven
    David Coleman replied 18 years, 2 months ago 4 Members · 3 Replies
  • Jeremy Garchow
    June 5, 2008 at 12:39 pm
    It really depends on your workflow.
    The HVX500 has bigger imagers, a more robust feature set, longer record times and better lens opportunities.
    The HVX200a has dv tape if you still need it and is less expensive.
  • Brad Neal
    June 5, 2008 at 12:44 pm
    Hi Steven,
    We have 2 500’s and will be adding a 170 as soon as it’s available – as you say, primarily for the size. But if size doesn’t matter, and you are not dealing with budget limitations, I see no compelling reason to go with the 200a.
  • David Coleman
    July 2, 2008 at 3:05 pm
    We have a Varicam, and a 2000 and hire shooters who own the 500, but when it comes time to put one on a jib, crane or dolly, the 200 comes in pretty handy.
