Covering Shadows That Are Not Suppose To Be In Frame
Debbie King replied 12 years, 4 months ago 2 Members · 17 Replies
Graham Bernard
May 19, 2014 at 2:51 amYou’re very welcome. I like your approach. The convergence in our approaches is this understanding of using the areas of image to move and improve others and then use the mask blending/feathering to make the thing seamless. Bit like pushing oils on canvass.
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Debbie King
May 19, 2014 at 6:42 pmHi Grazie:
Here’s the photo of the last attempt to cover the shadow. I used the picture on top of picture approach. As mentioned, I took a small part of the wall and filled it in with content aware. With a solid color wall, it may have been a perfect fit, but this is a patterned wall with grooves, and the grooves are stretched. I supposed I have to determine which is more distracting, a moving shadow however slight, or a part of a wall that’s slightly different than the rest.
Your thoughts!
Many thanks,
Debbie
P.S. The area on top that looks like a tear. I can redo and have it placed somewhere unseen; like the bottom perhaps.
PIXALATE, FILL LIGHT AND BUMP MAP
PIXALATE OF PART OF WALL NEXT TO ATTACHED PIC
Graham Bernard
May 20, 2014 at 6:03 amHmmm…
_______________________________________________________________
[Debbie King] ” I supposed I have to determine which is more distracting, a moving shadow however slight, or a part of a wall that’s slightly different than the rest.
Your thoughts!”
_______________________________________________________________My thoughts? – I prefer my approach as it blends well and distracts little. My “further” thought is why you aren’t using mine? You asked – I reply! But hey, it’s YOUR choice at the end of the day.
My further, further thought is that you could also get busy and create a faux (false) SHALLOW DoF of that wall. Then all this would be kinda irrelevant anyway.
Cheers
Grazie
Debbie King
May 20, 2014 at 7:28 amHi Grazie:
Yours would be perfect except that because the shadow was moving I could still see it even though it was less shown. If it were static, it would work perfectly. What I am trying to do is block him entirely because he is in constant movement. You’re right, the patterns are not identical because what I did with the content aware stretched it. The question is what is more distracting a slightly off wall or a shadow in movement. Tough spot for me right now.
I will also try the depth of field and see how that works. Thanks for the idea.
Many thanks,
Debbie
Graham Bernard
May 20, 2014 at 7:40 am_______________________________________________________________
[Debbie King] “Yours would be perfect except that because the shadow was moving . . The question is what is more distracting a slightly off wall or a shadow in movement”
_______________________________________________________________Ah, gotcha! – Could you upload a small Vid of the “worst” of the shadow-movement? No promises here, but I’m not done either!
G
Debbie King
May 21, 2014 at 3:16 pmHi Grazie:
Good idea. I have to figure out how to block the characters, because at this stage I cannot show any part of the movie. I was told that that can disqualify films for festivals that require world premiere. I’ll figure it out.
Many thanks,
Debbie
Debbie King
May 21, 2014 at 4:26 pmGrazie: I just looked at the photo that I shared with you, and that one is the worst of all of them. The others are a little further back, but very noticeable. This one is his head, the others are partial head, camera and tripod or hand.
Many thanks,
Debbie
