Activity Forums Apple OS X cover flow
  • cover flow
    Posted by Marcel Tiemensma on April 19, 2008 at 4:01 pm
    I have a movie and when it shows up in cover flow you see the first frames of the movie.
    Can I replace that with a picture (for ex front cover of the dvd)?
    Jeff Carpenter replied 18 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Simon Carlson-thies
    April 19, 2008 at 4:16 pm
    The only way I can think of to make that work is try making a poster frame of whatever you want to display. So if its a DVD cover add the image to front of the movie and set it as a poster frame for the movie. Other then that I’m not sure.
    Simon Carlson-Thies,
    Complex Technology Development
  • Marcel Tiemensma
    April 19, 2008 at 5:59 pm
    when i drag the picture to the fron of the movie it doesn’t show up. neither does set poster frame work. I.e. I set a poster frame but it doesn’t show up in the folder.
    Related question: can normal folders also show pictures in coverflow (upon the folders)?
    April 19, 2008 at 10:48 pm
    Yes if you change the icon it should work.
  • Marcel Tiemensma
    April 20, 2008 at 6:29 am
    ok, but how can i change the icon?
  • Jeff Carpenter
    April 21, 2008 at 4:36 pm
    Select a file or folder and hit command-i (or right click and ‘get info’).
    You get the inspector window for that file and you’ll see its icon in the upper left. Then, open the info on any other file or icon that you want to use. Click the icon in the inspector and copy it (command c).
    Then select the icon in the first file and paste (command v). It will over-write the icon with the new one. So you could make a folder look like iPhoto, or a Word file look like a folder.
    So to recap, you’re copying and pasting the icon in the “get info” windows for each file.
    You can get icons all over the web, but here’s some great places to start:
    https://www.apple.com/downloads/macosx/icons_screensavers/
    https://interfacelift.com/icons-mac/
    Also, you can turn an image INTO an icon using this free program:
    https://www.shinyfrog.net/it/software/img2icns/
    So you could cut out your head in Photoshop and use that to turn it into an icon.
  • Marcel Tiemensma
    April 21, 2008 at 5:08 pm
    i tried…but the folder’s icon shows a jpeg-icon and not the actual photo itself….(?)
  • Jeff Carpenter
    April 21, 2008 at 5:20 pm
    Images need to be turned into icons. Download this program:
    Drag the JPEG onto it and it will create an icon that looks like the photo. Then use that.
