Activity Forums Adobe After Effects Couple questions that bug me
  • Couple questions that bug me
    Posted by Devin Earthman on April 7, 2007 at 7:00 pm
    Sorry if these have been brought up before (probably) but I couldn’t find them after some searching.
    I wonder what’s happening with certain footage when I set it to loop x number of times in footage properties–it looks fine in previews, but rendered out they freak out after the first run and start to flicker/pause etc…This happens not all time but with various formats (DVCPro HD, uncompressed, interlaced and progressive, etc) I get around it with time-remapping by hand, but what gives? Sucks after a 1 hour render to discover this issue…
    Also, why the hell when you paste multiple layers into a comp are they ordered backwards? Is this a feature? 😀 Cause it sure as heck is annoying, is there a trick to this?
    Sorry for all the negativity, but these things are getting to me at the moment with a bit of a deadline crunch!
    Thanks in advance
    Dan Blaim replied 19 years, 5 months ago 2 Members · 1 Reply
  • Dan Blaim
    April 7, 2007 at 7:40 pm
    Not sure about the rendering problem but the copy is done in the order in which you select the layers. The layers are placed from top layer to bottom layer when you paste. Try selecting your layers that you are trying to copy in reverse order.
