Activity › Forums › Adobe InDesign › Couple of text wrapping questions
  • Couple of text wrapping questions
    Posted by Mike Jones on September 28, 2015 at 11:13 am
    I’m not entirely sure “wrapping” is the correct term, so forgive me.
    My two questions are :
    (1) If I have a long line of sub-header text, how can I ensure it wraps evenly, rather than just placing one or two words on the next line
    (2) In Table Of Contents, how can I enforce a wrap so that text does not flow to the end of the line ?
    A picture = 1000 words as they say, so please see image attached which outlines both “problems” I am having.
    Thanks !
    Kalleheikki Kannisto replied 10 years, 12 months ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    September 29, 2015 at 9:50 am
    1) Use “Balance ragged lines”:
    https://helpx.adobe.com/indesign/using/aligning-text.html#create_balanced_headline_text
    2) You can use right indent with a matching but negative last line indent value to force everything but the last line of a paragraph to break earlier.
    Both can be used in the paragraph formatting of your TOC.
  • Mike Jones
    September 29, 2015 at 12:11 pm
    Hi Kalle,
    Yeah, I tried “balance ragged lines”, it sort of works, but isn’t as ruthless as I’d like it to be. Also its kinda broken if you’re using left-just.
    Will have a look into your second suggestion though.
    Thanks !
    September 29, 2015 at 12:16 pm
    You wouldn’t use it with justified text, as justification would just overrides the balancing.
    How “ruthless” do you want it to be? If you want the first line to always be shorter than the second line, I guess you could try and combine it with left indent/last line indent.
