couple of Red questions
couple of questions:
1. I am trying to ingest lots of Red Footage into Premier.
When I import, I have to choose “import folder” in order to get all footage in. But then, aside from the R3D file, it also imports all the .mov (Ref. files) It takes me a long time, to remove them, since there are really a lot of clips.Is there an option, only to import the R3D files? Or if not, just group them together in the Media Folder, where I could delete all .mov files?2. when I export a clip, it always names it “Sequence 1”. When I look in the Media Encoder it says Source: Sequence 1. I can not find the option to preserve (and export) the clip with the original file name.
Thank you.
