Activity Forums Adobe Premiere Pro Couple of questions
  • Couple of questions
    Posted by Ron Dangus on May 2, 2010 at 3:00 pm
    Hi guys,
    I’ve got a couple of questions. I’m using Premiere Pro CS3 to edit since i can’t export in CS4. The Media Encoder doesn’t work.
    I’m trying to get clips from PPCS3 intro After Effects CS4, but when I copy paste a clip, it pastes the entire sourcefile instead of just the clip of a few seconds. Anybody know a way around this?
    Other problem I have: when i export the movie, the quality is a lot less, my 16:9 working material and edited film gets letterboxed in a 4:3 frame. I read that has something to do with compressors, but I can’t find anything in preferences.
    Any solutions?
    Ron Dangus replied 16 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Vince Becquiot
    May 3, 2010 at 4:45 pm
    Ron,
    We’ll need to know where the footage comes from, its PAR, resolution, as well as your project settings.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Ron Dangus
    May 3, 2010 at 5:32 pm
    It’s HD1080i material I recorded with a Sony HDR HC7,captured in PPCS4 and then imported as DV-pal in PPCS3.
    Par is 576-704.
    These are the settings: https://i44.tinypic.com/1ha6n4.jpg
  • Vince Becquiot
    May 3, 2010 at 9:10 pm
    [Ron Dangus] “I’m trying to get clips from PPCS3 intro After Effects CS4, but when I copy paste a clip, it pastes the entire sourcefile instead of just the clip of a few seconds. Anybody know a way around this? “
    Are you pasting the clip from your Premiere timeline to the After Effects composition?
    In AE, select the composition panel and hit “Home” first to make sure you are at the starting frame in your timeline then use “ctrl+alt+v” to paste the in point at the beginning of that layer.
    [Ron Dangus] “Other problem I have: when i export the movie, the quality is a lot less, my 16:9 working material and edited film gets letterboxed in a 4:3 frame. I read that has something to do with compressors, but I can’t find anything in preferences. “
    The best way to work in After Effects is square pixels. Set each comp settings to 1920×1080 (HDTV 1080 preset) and export lossless. That should give you the correct resolution and PAR back into Premiere.
    Vince Becquiot
    Kaptis Studios
  • Ron Dangus
    May 4, 2010 at 10:11 am
    Thanks for your response Vince,
    Ow, I wasn’t clear enough, I meant exporting in Premiere Pro CS3. I checked the adobe media encoder, and found a bunch of options there. What is the best quality to export? I found 1080p as wmv, as mov, as mpg, … (didn’t find the avi, though).
    Mov is completely uncompressed, so I guess that would be the best one, or is isn’t the difference with avi that big? (How do I export a 1080p avi anyways?).
  • Vince Becquiot
    May 4, 2010 at 4:41 pm
    Ron,
    What are you export for, playback?
    Quicktime Animation is as close as it gets to uncompressed. If this is for playback, try H.264 instead. 1920×1080 square.
    Vince Becquiot
    Kaptis Studios
  • Alex Udell
    May 5, 2010 at 3:43 pm
    Vince…
    “In AE, select the composition panel and hit “Home” first to make sure you are at the starting frame in your timeline then use “ctrl+alt+v” to paste the in point at the beginning of that layer.”
    this is a GEM.
    the timing offset of straight CTRL V has been driving me bananas….
    Alex
  • Ron Dangus
    May 5, 2010 at 7:25 pm
    I’ll get back at the exporting later, cause that’s still giving me problems, but I’ve got a problem with AE too. Thanks to the help of Vince and Alex the importing from PPCS3 footage into AECS4 has worked, but vice versa doesn’t. Any clues?
