Activity Forums Sony Cameras Country setting in menu PMW500
  • Country setting in menu PMW500
    Posted by Robin Probyn on March 23, 2012 at 3:57 am
    Hi there
    I read when the camera is new.. you are given a choice of NTSC/PAL in a Country setting window.. but if you want to change between PAL or NTSC after that.. where is the country setting in the menu.. I have the manual but dont see it there.
    Presuming you do have to change the country setting to change between NTSC or PAL format options..
    Robin Probyn replied 14 years, 6 months ago 1 Member · 1 Reply
