Activity Forums Apple Final Cut Pro Legacy Countless Time Code Breaks- What’s the Best Way to Capture?
  • Countless Time Code Breaks- What’s the Best Way to Capture?
    Posted by Jason Mccaffrey on August 11, 2005 at 6:46 pm
    Hello,
    I’m helping a friend edit some home video of a vacation. Pretty much every time he stopped and started the camera he generated a time code break. If I dub these tapes onto striped tapes will they maintain their original time code or the new tape’s timecode? Is there a way to do this to make my life easier?
    Jason
    400 MHz Power Mac G4 2.9
    832 MB SDRAM
    (256 256 256 64=832-everyone asks)
    FCP 4.5
    QuickTime 6.5.2
    Sean Oneil replied 21 years, 1 month ago 5 Members · 5 Replies
  • Bouncing Account needs new email address
    August 11, 2005 at 6:57 pm
    No, but a FireWire copy IS standard procedure to correct this problem.
    You do NOT need to dub to a “striped” tape.
    Just hook two camcorders (or decks) together via FW and just make a full new copy of the “broken TC” tape to a new DV tape.
    Then, only capture and edit from the copy.
    99% of all camcorders and decks will NOT re-dub the original TC, but simply generate new continuous TC on the new tape when in the record mode.
    If your friend gave you edit marks based on the original tape’s bad TC, you can have him/her give you new instructions based on the new copy.
  • Eddie Torre
    August 11, 2005 at 7:31 pm
    If you want, you could use the original tape and set this preference…
    Final Cut Pro>User Preferences>On timecode break: Make New Clip
    August 11, 2005 at 8:04 pm
    [Eddie Torre] “Final Cut Pro>User Preferences>On timecode break: Make New Clip”
    This is not a method I’d recommend, given the tape that was described.
    This procedure has been generally more unreliable and you “lose” quite a bit of footage at every “break” (not good if a non-pro has shot the footage and wants the beginning of almost every shot.)
    Plus, if you want to Batch Capture, FCP will not be able to comply, as there are numerous sections with identical TC.
  • Dean Goldsworthy
    August 11, 2005 at 8:06 pm
    Why not just set device control to “non-controllable” in the capture window, that way you generate new TC on capture.
  • Sean Oneil
    August 11, 2005 at 9:39 pm
    It’s very important not to lose the ability to batch capture later on. Like Matte said, make a new copy of the tape with new, continuous timecode. Do a deck to deck Firewire transfer. Or, if you only have one deck, change the FCP settings to “Ignore Timecode Breaks.” Then capture an entire time and then create new tapes from the captured files using new TC. And then capture from the new tapes and edit those.
