Activity Forums Adobe After Effects Expressions Counting using a slider but adding a word after the numbers..
  • Counting using a slider but adding a word after the numbers..
    Posted by Alex Dinnin on October 9, 2014 at 2:22 pm
    Basically..
    I need to create an expression that adds a word onto the end of a counting number
    I need it to go from 0 to 100 “MILLION” the text stays the same it’s just added onto the line
    so it counts 1 MILLION, 2 MILLION 3 MILLION etc etc
    So I’m using this expression for my counting numbers
    val = effect(“ZEROES”)(“Slider”);
    numDec = 0; // digits to right of decimal
    numDigit = 0; // digits to left of decimal
    if (val < 0) sign = “-” else sign = “”; s = Math.abs(val).toFixed(numDec); while (s.length < numDigit + numDec + 1) s = “0” + s; sign + s
    I just need to add the word MILLION at the end… is this possible ?? I can’t use a seperate layer as I have some crazy other expressions linking to this text layer ?
    Any ideas..
    thanks as always
    Alex
    Alex Dinnin replied 11 years, 10 months ago 1 Member · 1 Reply
  • Alex Dinnin
    October 9, 2014 at 2:30 pm
    I found something Dan had supplied earlier.. I’ve looked for blooming hours before resorting to asking for help..
    then as soon as I hit post.. I find this about ten seconds laters..
    s = Math.round(effect(“ZEROES”)(“Slider”)).toString();
    outStr = s.substr(-s.length, (s.length-1)%3 +1);
    for (i = Math.floor((s.length-1)/3); i > 0; i–){
      outStr += “,” + s.substr(-i*3,3);
    outStr + ” MILLION”;
    Thanks for reading
