Activity Forums Adobe After Effects Counter – “moving” numbers
  • Counter – “moving” numbers
    Posted by Thais Maranho on April 4, 2019 at 3:24 pm
    Hey all,
    I’m working in this counter from 0 to over 306 million. I managed to make it work just fine but the client don’t want the commas and the numbers to move to left and right. They want the commas and the space between numbers to be steady/locked.
    Any idea how to do that?
    I’m using “Point control” on the text layer and the following expression:
    s = “” + Math.round(effect(“Point Control”)(“Point”)[0]);
    s.replace(/\B(?=(\d{3})+(?!\d))/g, “,”);
    Thank you,
    Kalleheikki Kannisto replied 7 years, 5 months ago 4 Members · 3 Replies
  • Oleg Pirogov
    April 4, 2019 at 10:29 pm
    If I got the problem right, first thing to do is to set paragraph to “Right align text”. This will leave you with just slight shifts of commas and numbers due to different width of number chars.
    Assuming this is still not acceptable, I then suggest using monospace font like Courier, with which your commas and numbers will always be at the same exact place. If you don’t like Courier, there are lots of others including such that resemble common non-monospace fonts.
  • Max Haller
    April 5, 2019 at 2:08 pm
    Theres probably a more elegant way, but I think the easiest way would be to set up the counting in groups of three digits.
    So you could have three text layers and the comas on separate layers so they aren’t affected. Like:
    xxx , xxx , xxx
    maybe just loop the first 3 digits going from 0-999 and time the other groups of digits to change accordingly.
  • Kalleheikki Kannisto
    April 6, 2019 at 4:17 pm
    Just saw this today: https://aescripts.com/monospacer/
    Senior Graphic Designer
