Activity › Forums › Adobe After Effects › Counter Control with Expressions
  • Counter Control with Expressions
    Posted by Jules Pontarius on October 4, 2012 at 7:54 pm
    We’ve been trying to create a flip clock type counter in After Effects for a client video, and have gotten a single digit flip counter in working order, so that as you scrub down the timeline the numbers increment up.
    However, we want it to be a three digit counter, and are having trouble thinking of an expression that would make the ten’s place holder increment up by 1 only when the one’s place holder transitions from 9 to 0.
    Can anyone out there help?
    Tudor “ted” jelescu replied 13 years, 11 months ago 3 Members · 4 Replies
  • Jules Pontarius
    October 4, 2012 at 8:05 pm
    Nevermind, on the ten’s place precomp we applied a time offset variable and basically divided it by ten.
  • John Cuevas
    October 4, 2012 at 8:10 pm
    Here’s an expression from After Effects Expressions that you might find useful:
    var startingMinute = 9;
    var startingSecond = 4;
    var seconds = Math.floor(time) + startingSecond;
    var minutes = Math.floor(seconds / 60) + startingMinute;
    var secondsAsPartsOfAMinute = Math.floor(seconds % 60);
    function addZeros(rawNumber)
    if (rawNumber < 10) return "0" + rawNumber;
    return "" + rawNumber;
    addZeros(minutes) + ":" + addZeros(secondsAsPartsOfAMinute);
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    That’s another good solution.
    Thinkck.com
  • Tudor “ted” jelescu
    October 6, 2012 at 3:59 pm
    You could also pre-compose the first animation and then Time Remap the pre-comp accordingly.
    Tudor “Ted” Jelescu
    Senior VFX Artist
