Activity › Forums › Adobe After Effects › Countdown with sounds
  • Oleg Plachkov
    July 4, 2016 at 2:46 pm
    The date goes down by 4 years in mere 7 seconds.
  • John Cuevas
    July 5, 2016 at 1:48 pm
    Dave is right that a sound for each day would be pretty extensive and probably not distinguishable. If you figure out that part, I would just take a sound file and drop it in a precomp and make it the length of one day. Add it to your final comp and enable time remapping, alt+click the keyframes to create an expression and just add the loop expression
    loopOut("cycle")
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
