Activity › Forums › Adobe After Effects › Countdown timer, again, but differnt…sorry!
Posted by Sam Baum on September 20, 2011 at 2:32 pmHi all
So, there’s lots of tutorials out there on building a countdown timer. But, I can’t seem to find one that suits my needs.
I need to produce a countdown timer from 90 to zero. No decimal points, just 90, 89, 88 etc etc.
Any ideas?
Thanks yall.
Sam
Abie Silva replied 15 years ago 4 Members · 8 Replies -
Sam Baum
September 20, 2011 at 2:42 pmHi Dave
As I need the counter to be 90 to zero and not 1.30 to zero, doesn’t this mean a need a differnt approach? I can’t get the usual methods to display numbers higher than 60.
Sam
Kevin Camp
September 20, 2011 at 2:52 pmyou can do this several ways, but a fairly simple, straight forward way is to create a text layer and add a slider expression control effect to the text layer.
then twirl down the text layer properties to get to the source text property and enable expressions for that property (select it and choose animation>add expression). in the expression field type Math.round( and drag the expression pickwhip to the sider value, then type ); after that. so your expression shoule look similar to this:
Math.round(effect(“Slider Control”)(“Slider”));
now if you key frame the slider value from 90 to 0 you should only get whole numbers.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Walter Soyka
September 20, 2011 at 2:56 pm[sam baum] “I need to produce a countdown timer from 90 to zero. No decimal points, just 90, 89, 88 etc etc. “
Assuming you are talking about 90 seconds:
- Create a text layer in your comp. Add some dummy text and format it to your liking.
- In the Timeline panel, twirl down the text layer (click the disclosure triangle next to the layer name), then twirl down the Text properties set, revealing the Source Text property.
- Alt-click the Source Text stopwatch, and enter the following expression:
90-Math.floor(time)
Explaining the expression from right to left:
- time yields the current comp time in seconds with decimals.
- Math.floor(time) returns that time value as an integer, ignoring everything after the decimal point.
- 90-Math.floor(time) subtracts that time value from 90 to create the countdown.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Sam Baum
September 20, 2011 at 2:57 pmHi Kevin
This is a beautifully simple solution! Thanks!
One other thing, is there a way when using this method that I can have all number have 2 charectors? So that 9 – 0 show like this. 09, 08, 07 etc etc?
Many thanks
S
Sam Baum
September 20, 2011 at 3:03 pmWalter, yet another beautifully simple solution. There truly is many ways to skin a cat!
Same question to you, is there a way when using this method that I can have all number have 2 charectors? So that 9 – 0 show like this. 09, 08, 07 etc etc?
Many thanks
S
Walter Soyka
September 20, 2011 at 3:06 pm[sam baum] “Same question to you, is there a way when using this method that I can have all number have 2 charectors? So that 9 – 0 show like this. 09, 08, 07 etc etc?”
Add a test to see if the countdown is less than 10. If it is, add a leading zero:
countdown = 90-Math.floor(time);
if (countdown < 10) {"0" + countdown} else countdownThe same method would work for Kevin’s solution, too.
Walter Soyka
Sam Baum
September 20, 2011 at 3:07 pmWhat a Legend! Thanks so much, I must say that I love this forum!
Have a great day everyone!
S
Abie Silva
September 20, 2011 at 3:18 pmI just used this and it worked great for me…
https://www.videocopilot.net/forum/viewtopic.php?f=5&t=10946&start=0
