Activity › Forums › Adobe After Effects Expressions › Countdown timer
Countdown timer
Posted by Eyesee on November 27, 2006 at 5:50 pmHi guys
Does anyone know how to do a countdown time in after effects?
We’re doing a boxing programme and need to create a countdown timer that counts down in seconds (NOT frames/timecode).
Any ideas very welcome!!!
Thank you!!!
Penpen_lord replied 19 years, 9 months ago 4 Members · 4 Replies -
Mylenium
November 27, 2006 at 5:56 pmSearch the forum. This has been covered a million times over and you will surely find a solution applicable to your situation.
Mylenium
[Pour Myl
Eyesee
November 27, 2006 at 6:06 pmHi there
erm – a *little* more help would use useful :o)
I found some posts that have the expression text (which may work)???). But how do I insert an expression? Where’s the command for it???
Please help!!!
Thank you!
Mike Clasby
November 27, 2006 at 7:17 pmAdding an expression:
Copy the expression (like copying text, Ctrl C), then Alt Click the Stopwatch for the parameter you want to add an expression to, then paste (Ctrl V). click outside the boxwhere the expression appeared and a little equal sign appears next to the stopwatch and the values are red, meaning the values are controlled by an expression. If you want to disable the expression click on the equal sign to break it.
Your countdown the expression probably needs to be applied to the Source Text parameter. You get there, by clicking on the screen with the Text Tool, where you want the countdown to be. Then in the new Text Layer, twirl down those little triangles for layer name and “Text” until you see the “Source Text” stopwatch. Copy, Alt Click the stopwatch, paste.
Note: Source Text is one of the few parameters that doesn’t have values showing, hence no red values. If you alt click something like Size or Rotation, you’ll see what I mean. Also an easy way to check for expression on a layer is to select it then hit “ee” (quickly) and the expressions will be exposed.
Penpen_lord
December 13, 2006 at 3:55 amCould someone link me to a tutorial on creating countdown timers?
