Activity › Forums › Adobe After Effects Expressions › Countdown like in the show 24
  • Countdown like in the show 24
    Posted by Chris Gu on March 27, 2006 at 10:31 pm
    I’d like to do a countdown like in 24, but I don’t know how to. Is there a preset countdown effect where I can simply put in 00:10:00 and have it count down every second? (It’s going to be like a joke type knockoff).
    Brian Charles replied 20 years, 6 months ago 3 Members · 2 Replies
  • Rahul Venugopal
    March 28, 2006 at 3:33 am
    May be u must try some plugins out there
    Just Go for It!
  • Brian Charles
    March 28, 2006 at 4:57 am
    You could emply the Numbers effect (under text in the effects menu) render the file and reverse the sequence.
    I’m sure you could write an expression to set the source text of a text layer. Alternately you could keyframe the source text of a layer to change when you want.
