Activity Forums Creative Community Conversations Countdown, FFoA, & Reel Breaks
  • Countdown, FFoA, & Reel Breaks
    Posted by Ryan Krickow on January 4, 2010 at 9:22 am
    I have a couple questions I’m hoping someone might be able to answer. If they’re inappropriate for this forum I’d appreciate it if you could point me in the right direction. I’m editing a feature length project in FCP7.0.1 and I’m going to be placing a countdown leader at the front of the timeline with a 2-pop before I pass the project off to post sound.
    First, I wanted to confirm that at the first frame of action (01:00:00:00) the movie (sound/music/titles/etc.) begins. There’s no need for adding extra seconds of black after a 2-pop, correct?
    Second, I’m wondering how reel breaks are typically marked in FCP when you’re passing the project off to post sound and/or color correction? Is there some kind of standard practice… using markers or possibly creating separate sequences?
    Thanks for any advice you can give me and have a Happy New Year!
    Abhayadev Sankaran replied 12 years, 4 months ago 4 Members · 4 Replies
  • Arnie Schlissel
    January 4, 2010 at 2:56 pm
    FFOA follows exactly 2 seconds after the 2-pop. Hence the name 2-pop.
    When you break your show up into reels, each reel gets its own timeline, complete with countdown head and tail pops. Most sound and picture finishing houses prefer to work in 20 minute reels.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Jim Blokland
    January 5, 2010 at 11:26 pm
    To add to Arnie’s response, each reel countdown normally starts at the appropriate hour mark, ie: Reel 2 countdown leader starts at 2:00:00:00, the 2-Pop is at 2:00:06:00 and program starts at 2:00:08:00. You also need to put a tail leader at the end of each reel, and the same thing applies in reverse. 2-Pop 2 seconds after last frame of picture, followed by a reverse count — up to 8 seconds.
    Hope this helps. Good luck with the film.
    Best, JIM.
    OSX.5.6
    Dual 2.7 G5
    5.5 GB RAM
    Radeon X800 XT
    Kona 2 / K-Box
    Seritek 1.5 TB RAID
    AVID XPRESS PRO/MOJO
  • Abhayadev Sankaran
    November 14, 2013 at 6:28 am
    recently in to post and learning bit by bit… just came across the standard process followed of putting the FFOA @ 1 hour and 2-pop just before it etc.
    Just was curious why the FFOA at 1 hour of time line and the entire time-line is empty till 00:59:00:00 ? Is there any documentation on this to refer to?
    appreciate your comments and replies.
    Regards,
    Abhayadev S
    May 9, 2014 at 1:10 pm
    So they all are stitched together/or an full length movie prepared for the Final Mix by the Video Editor?
    Regards,
    Abhayadev S
    https://astudios.in
