Activity Forums Adobe After Effects Expressions Countdown clock expression error
  • Countdown clock expression error
    Posted by Andrew Ross on May 1, 2026 at 2:52 pm
    I could do with some help on this countdown clock please.
    I’ve got a script off the internet but it’s kicking up an error and I’m not sure why…
    This is the section of expression
    // Round to whole numbers and add zero padding
    for (i in f){ f[i] = String(Math.floor(f[i])).padStart(i>2?3:2, “0”) }
    and this is the error message
    The error reads : Error at line 17 ‘Source Text’ of layer 1(‘Timer’) in comp ‘Comp 17’. String ().padStart is not a function.
    w
    I hope you can help. Many thanks in advance.
    Tim Garber replied 2 months ago 4 Members · 5 Replies
  • Dan Ebberts
    May 1, 2026 at 3:09 pm
    Can you post the whole expression (or a link to where you got it)?
  • Dan Ebberts
    May 1, 2026 at 3:44 pm
    My guess, based on the error message, is that you have the expression engine set to Legacy Extendscript. Try:
    File > Project Settings > Expressions > JavaScript
  • Andrew Ross
    May 7, 2026 at 9:42 am
    Hey Dan! Yep, that did it. Thank you
  • Brie Clayton
    May 7, 2026 at 1:32 pm
    Thank you, Dan!
  • Tim Garber
    July 7, 2026 at 10:08 pm
    That gets me everytime I jump on a new machine.
