Activity › Forums › Adobe After Effects Expressions › countdown clock
  • Filip Vandueren
    December 14, 2005 at 12:32 am
    Hey Echo,
    do a search in the archive for “clock”, there’s a few ways, some people do it with the “numbers” effect, but using expressions gives you more control.
    BTW:
    try to make the animation calm (eg. don’t use 100ths of seconds), that way you can export a 1fps movie and use the animation codec with a high number for keyframing, otherwise you’re 2-hour-long quicktime will get pretty darn huge…
