Activity › Forums › Adobe After Effects Expressions › Count up Expression
Count up Expression
Posted by Benmcewan on July 22, 2007 at 11:23 amOk well I want an expression that will count from 0 – 60 between
0:03:00:22 and 0:03:06:00 (I’m running in 25 frames per second); or just between 2 keyframes if you can do it that waySam Moulton replied 19 years, 2 months ago 6 Members · 7 Replies -
Mike Clasby
July 22, 2007 at 5:43 pmDan’s Universal Up/Down Clock should do the trick:
https://www.motionscript.com/design-guide/up-down-clock.html
Benmcewan
July 23, 2007 at 6:22 amI don’t want it in a time format though, I want it just to count from 0 – 60 between two keyframes
Lord Scales
July 23, 2007 at 6:44 pmThis should help more… https://www.motionscript.com/design-guide/counter.html
In a simplified way:
startTime = 1.5; //in seconds
endTime = 5; //in seconds
startValue = 0;
endValue = 60;linear (time, startTime, endTime, startValue, endValue)
Apply it in a text layer, in the property Source Text.
I am not with AE here, so I did not tested it, but I think it works.
Dan Ebberts
July 23, 2007 at 7:12 pmJust one note – be careful using “startTime” as a variable name because there is already a layer attribute with that name. I found this out the hard way. 🙂
Dan
Darby Edelen
July 24, 2007 at 1:36 am[Lord Scales] “startTime = 1.5; //in seconds
startValue = 0;
endValue = 60;linear (time, startTime, endTime, startValue, endValue)”
You can also modify this to use keyframe times automatically.
key(1).time
Should give you the time in seconds where the first keyframe of the property is,
key(2).timewill give you the second.Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA -
Darby Edelen
July 24, 2007 at 1:40 amJust an addendum to that,
key(1).timewill give you an error if you don’t have any keyframes for that property. You should be able to try() and catch() these errors in the expression though:https://www.w3schools.com/js/js_try_catch.asp
(AE uses JavaScript with custom classes/methods/variables for its expressions)
Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA -
Sam Moulton
July 28, 2007 at 12:47 amfor something this simple I’d just use an expression slider and pick whip to it, then animate the slider by setting 2 keyframes. Use math round or math floor to get rid of the decimals.
Math.floor(effect(“Slider Control”)(“Slider”))
