Activity › Forums › Adobe After Effects Expressions › Count-up expression
  • Count-up expression
    Posted by Deniz Nasif on October 25, 2011 at 5:59 pm
    I currently have numbers counting up using the following expression:
    beginTime = 0;
    endTime = 15.02;
    startVal = 0.00;
    endVal = 15;
    Math.round(linear(time,beginTime,endTime,startVal,endVal))
    However, I want to add decimals to it, so it basically says 0.00. Any help would be greatly appreciated.
    Many thanks in advance.
    Dan Ebberts replied 14 years, 7 months ago 3 Members · 6 Replies
  • Dan Ebberts
    October 25, 2011 at 10:30 pm
    If you just want to add “.00” to the result, change the last line to this:
    Math.round(linear(time,beginTime,endTime,startVal,endVal)) + “.00”
    If you actually want two decimal places in the result, you would change it to this:
    linear(time,beginTime,endTime,startVal,endVal).toFixed(2)
    Dan
  • Deniz Nasif
    October 26, 2011 at 6:14 am
    Excellent Dan. Thank you very much for your help 🙂
  • George Fragakis
    January 23, 2012 at 9:45 pm
    hey, first post here so be gentle. 🙂
    I wan’t to get the same effect only i need my final number to have “.” between digits.
    Specifically I need my count to start from €0 and get to €50.000.000
    I have this expression (which I found here on another amazing thread):
    beginTime = 0;
    endTime = 5;
    startVal = 100;
    endVal = 1200000,00;
    “€” + Math.round(linear(time,beginTime,endTime,startVal,endVal))
    How can I get it to work with “.” in between ? Thank you so much in advance
    beginTime = 0;
    endTime = 5;
    startVal = 100;
    "â
  • Dan Ebberts
    January 23, 2012 at 11:42 pm
    This should work:
    beginTime = 0;
    endTime = 5;
    startVal = 0;
    endVal = 50000000;
    s = "" + Math.round(linear(time, beginTime, endTime, startVal, endVal))
    prefix = "€";
    outStr = s.substr(-s.length, (s.length-1)%3 +1);
    for (i = Math.floor((s.length-1)/3); i > 0; i--){
    outStr += "." + s.substr(-i*3,3);
    "€" + outStr
    Dan
  • George Fragakis
    January 26, 2012 at 11:27 pm
    worked like a charm Dan, thank you. Now to add ,88 at the end? (or any other decimal for that matter?)
  • Dan Ebberts
    January 27, 2012 at 12:53 am
    I’m guessing this isn’t really what you want, but you could change the last line to:
    “€” + outStr +”,88″
    If what you really want is the fractional part of the count rounded to two digits, I really wish you had mentioned that to start with, before I ripped all that stuff out of the expression.
    Dan
