Activity Forums Adobe After Effects Expressions Count Shape Layers
  • Count Shape Layers
    Posted by Tavo Galvez on June 25, 2023 at 1:00 am
    Hi, I am new to after effects expressions and I would like to know if there is an expression that counts the shape layer or shows me the written text when the shape layer reaches a point in the position.
    In the image C1 when it reaches the dotted rectangle changes the text to 01, I would like that when the C2 reaches the position of the dotted rectangle also changes the text…and so the shape layers. Thanks.
    Tavo Galvez replied 3 years, 2 months ago 2 Members · 4 Replies
  • Filip Vandueren
    June 26, 2023 at 9:55 am
    Hey Tavo,
    do you want to count how many layers are hitting the target at the same time ?
    So if C1 and C3 would overlap in the square it would be resulting in 2 ?
    Do you want the position to be very precise, or is it more of a collision check: when the squares touch, they count ?
  • Tavo Galvez
    June 29, 2023 at 5:19 am
    Hi Filip and thanks, yes I want to know how many layers are hitting the target.
    I want to know how many layers are hitting the target, so I want to know how many layers are hitting the target.
    Either by collision or by position. If a shape layer reaches that point that the text change to 1, if another shape layer arrives, change to 2 and so on, the problem is that I can not get it with expressions.
  • Filip Vandueren
    June 29, 2023 at 9:33 am
    Here’s one way to do it:
    assuming I want to check three layers that are layers 1, 2, and 3 and see if their position is less than 100 pixels form my target layer.
    I’m also assuming non of these layers are parented for now.
    I would give the text-layer’s sourceText property this expression:
    num = 0;
    for (i=1; i<4; i++) {
    if (length(thisComp.layer(i).position - thisComp.layer("target").position)<100) {
    num++;
    num;
    This straight line distance works better for 100×100 circles. You could change it to <1 and it will only count if they are at the exact same location.
    For squares that are all 100×100 pixels this kind of check is maybe better:
    num = 0;
    if (
    Math.abs(thisComp.layer(i).position[0] - thisComp.layer("target").position[0])<100
    Math.abs(thisComp.layer(i).position[1] - thisComp.layer("target").position[1])<100
    num++
    num
  • Tavo Galvez
    June 29, 2023 at 3:14 pm
    Thank you very much Filip, the expression works correctly.
