Activity Forums Adobe After Effects Count frames until an animation property reaches a certain value
  • Count frames until an animation property reaches a certain value
    Posted by Klaus Hertweck on May 16, 2025 at 9:50 am
    I have a simple animation, a shape layer is moving from left to right.
    Now I want know at which frame the X-value of the reaches 500.
    I have set up this expression, but it does not work:
    var compLength = thisComp.duration / thisComp.frameDuration;
    var posX = thisComp.layer(“shape”).transform.xPosition;
    for (i = 0; i <= compLength; i++) {
    posX.valueAtTime(framesToTime(i)) = 500
    i
    i should return the frame value, but is doesn’t.
    Any help would be greatly appreciated.
    Brie Clayton replied 1 year, 3 months ago 4 Members · 6 Replies
  • Dan Ebberts
    May 16, 2025 at 11:07 am
    You were close. Try it this way:
    var posX = thisComp.layer("shape").transform.xPosition;
    if (posX.valueAtTime(framesToTime(i)) >= 500) break;
    i
  • John Martin
    i’m recording a custom tutorial for you with the solution, just wait for a little bit and you’ll see it!
  • John Martin
    May 16, 2025 at 11:48 am
  • Klaus Hertweck
    May 16, 2025 at 12:55 pm
    Hi Dan,
    thanks a lot! This works perfectly!
  • Klaus Hertweck
    May 16, 2025 at 1:00 pm
    Hi John,
    thank you very much for visualising your solution!
  • Brie Clayton
    May 16, 2025 at 11:27 pm
    Thanks for solving this, John!
