Activity Forums Zaxwerks Couldn’t find main entry point for 3D Invigorator plug-in
  • Couldn’t find main entry point for 3D Invigorator plug-in
    Posted by Brian Moran on April 23, 2009 at 8:11 pm
    So that’s the error message, “Couldn’t find main entry point for 3D Invigorator plug-in”. Invigorator plug-in won’t load, After Effects freezes, existing projects can’t be opened…not good.
    Anyone seen this?
    Edward Wu replied 17 years, 5 months ago 2 Members · 3 Replies
  • Edward Wu
    April 23, 2009 at 11:46 pm
    Hi Brian,
    I would try downloading and installing the latest version of 3D Invigorator Pro (version 4.5.1) if you haven’t done so already. If you have, try re-installing the plug-in again, and applying Invigorator Pro to a Color Solid, and see if you are still having issues.
    Best,
    Edward
  • Brian Moran
    April 24, 2009 at 2:07 pm
    Thanks Edward – I was already using version 4.5.1, but I tried downloading a ‘fresh’ copy and reinstalling, since that seems to be Zaxwerks’ solution to any problem. It had no effect, same error message, same AE freeze.
    But, in goofing around with the plug-in I discovered that for some reason it was trying to open up in a older version of After Effects (that I need to keep installed for working on other people’s projects). Once I reset that Invigorator preference (in ‘Get Info’ on a Mac), everything was fine. Go figure.
    Brian
  • Edward Wu
    April 24, 2009 at 5:38 pm
    Hi Brian,
    Thanks for sharing your solution. Good to hear that it’s working out for you now.
    Best,
    Edward
