Activity Forums DVD Authoring could this be a dvd sp issue?
  • could this be a dvd sp issue?
    Posted by Antonio Atzei on June 12, 2007 at 12:39 pm
    I may been asking the wrong question before so here I go again.
    Let`s say that you want to cut down the ammount of light/luminosity in your final project. How should I go about?
    Apparently every attempt give`s me the same outcome.
    A- cutting the ammount of whites or mids
    B- cutting down the opacity
    I also tried some filters with no success
    The bottom line is that I need to lower the luminosity of the clip and make sure that during output to sd dvd keeps that setting.
    Any suggestion please, or point e in the right direction.
    The dvd looks fantastic it`s only to bright.
    ciao
    Antonio Atzei
    Noah Kadner replied 19 years, 2 months ago 2 Members · 1 Reply
  • Noah Kadner
    June 13, 2007 at 4:54 pm
    Hmm- you can use the color correction and broadcast safe in FCP to bring luma down. There’s a slight shift when you got out to DVD maybe a point or two in IRE but nothing major. You can also apply an overall gamma filter in Compressor to help.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
