Activity Forums Adobe Premiere Pro could not synchronize clips because a match could not be found
  • could not synchronize clips because a match could not be found
    Posted by Mike Gurfield on May 12, 2014 at 3:40 am
    Over and over and over again. I have external audio and am trying to sync with Red footage. About 15% of the shots have managed to sync, the others I’m having to do by hand. But I keep getting this error. I’ve trashed the media cache, trashed the preferences… I’m at a loss here, as these audio files CLEARLY match the camera audio… the audio is all well recorded and should not be an issue. HELP!
    Tova Hirsch replied 2 years, 4 months ago 5 Members · 6 Replies
  • Dennis Radeke
    May 12, 2014 at 10:19 am
    Assuming you’re using CC?
    Are you on the latest release?
    Are you syncing via audio or timecode?
    Can you sync in any way?
    If trying to sync audio and failing, perhaps try normalizing the separate audio feed and try again? Maybe the level is too low.
  • Mike Gurfield
    May 12, 2014 at 12:06 pm
    Sorry for all the lack of info. Brain was fried after a long day and frustration.
    Yes Premiere Pro CC latest version. I’m trying to sync with audio, as the time code is for some reason inconsistent across the clips even though time code was sent on set (some clips match, most do not). Synchronize with audio worked fine on the first few clips, synching to audio on track 2 (track one of the camera audio is blank, track two is camera audio, then I have 5-channel audio 1 I’m attempting to sync). Then I randomly started getting that error I posted. I resorted to manually syncing the audio, which takes forever. I managed to find some success late in the night using a similar audio sync, but changing the drop-down from “track 2” to “mix down”. For some reason, it was able to sync with no issues there for the last 10 or so clips, as I had already powered through the rest. Can’t say if that is a real fix of not, as my original workflow worked for a few clips at the outset as well…
    Trashing prefs and and media cache had no effect, but everything is at least in order now…
    I’m curious why you think normalizing would help. And would you think normalizing both clips would be the right workflow? Theoretically, these clips should just sync without issues, as the audio is good and clean, all has been marked with a clear clap stick. But se la vie…
  • Paulina Rouge
    July 20, 2015 at 7:40 pm
    I’ve been having this problem for ages but what sorted it for me was choosing 2 instead of 1 under Track Channel.
  • Tova Hirsch
    May 14, 2024 at 4:49 pm
    Having this issue. I have audio that is very clear and it won’t synchronize. Getting the error that a match can’t be found.
    May 14, 2024 at 5:04 pm
    Hey Tova,
    Out of interest, in what channel is your recorded audio channels based?
    Sometimes a camera might only have recorded camera microphone audio on channel 3 & 4, and if you are syncing to channel one only, this may be the cause for why it will not sync.
  • Tova Hirsch
    May 14, 2024 at 6:30 pm
    It looks like its all on channel 1
