Activity › Forums › Adobe Premiere Pro › Could not open the project file with write access.
  • Could not open the project file with write access.
    Posted by Kira Pogge on October 24, 2014 at 4:56 pm
    Hello – I’m new to Premiere and have been using Sony Vegas for years. I’m just learning my way around the interface and its great so far. However, when I go to save a new or an existing project I keep getting this error message. “Could not open the project file with write access. The File may be locked or you may not have access to write to this location. Select ‘SaveAs’ from the File Menu to save the project to a new location.”
    I’m not sure what to do as I haven’t encountered this so often in the past and am able to write other files to the folders I’m discussing. Also, when I do SaveAs to a new location and then try to Ctrl s to save the file after having worked on it I get the same message.
    I really appreciate any insights or help you might be able to share.
    Kira
    Kira Pogge replied 11 years, 11 months ago 3 Members · 6 Replies
  • Daniel Waldron
    October 24, 2014 at 5:22 pm
    Have you checked the properties of the file to make sure you have write access and not just read access? This has nothing to do with Premiere, but can be checked in Windows Explorer or the the Mac Finder, depending what OS you’re on.
  • Kira Pogge
    October 24, 2014 at 5:33 pm
    Thanks for the tip – I did just look and I do have write access as well.
  • Kevin Monahan
    October 24, 2014 at 6:31 pm
    Hi Kira,
    Do you use network drives?
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Kira Pogge
    October 24, 2014 at 6:32 pm
    Hi Kevin – Yes we use network drives at the firm I work for. 🙂
  • Kevin Monahan
    October 24, 2014 at 6:37 pm
    Hi Kira,
    I’m fairly certain that’s where your issue lies. I suggest you work locally and use the network drive only to backup media and projects. Is that possible?
    Kevin
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
  • Kira Pogge
    October 24, 2014 at 6:40 pm
    Thanks for the feedback Kevin! I’ll give it a shot for sure.
    Thanks to everyone in this feed for their help and suggestions. Creative Cow is seriously one of the best resources for anyone in the video/effects/cinematography realm! 🙂
    Happy Weekend!
