Activity Forums Adobe After Effects “Could not create Image Buffer”
  • “Could not create Image Buffer”
    Posted by Helgi Johannsson on September 18, 2006 at 7:27 pm
    I’m working on a project with very big pictures (some of them are 5000×3000 px up to 10000×8000 px). I’m using them as backgrounds for 10-bit blue screen footage. Now when I render out I get the error “Could not create XXXX x XXXX image buffer” very often (XXXX x XXXX are the pixel values for the background footage). When I get this error, the render stops and fails.
    So I’m asking you guys if you know a solution to this problem because otherwise I can’t do nothing! Big problem.
    Btw, if it helps I’m using a G5 with 2GHz and 3 GB RAM.
    Helgi Johannsson replied 20 years ago 10,679 Members · 1 Reply
  • Helgi Johannsson
    September 18, 2006 at 7:42 pm
    Nevermind guys, I can’t believe I asked a question somebody asked last 11 September 2006 :s . I know I should have searchd the forums but I was very frustrad or sth..
