Activity › Forums › Adobe After Effects › Could not allocate sound memory issue.
  • Could not allocate sound memory issue.
    Posted by Ruud De ruijter on April 10, 2016 at 11:02 am
    So when I want to play my composition in adobe after effects, using that play button on the right side of the screen it says this error: could not allocate sound memory. When I press the period key on my numeric keyboard, then I just hear the sound. I made a sound visualizer, if that helps. When I import my adobe after effects project into premiere pro and if I play it then it just repeats a bit of a music file over again and again. I hope that someone can help me with this issue.
    Ruud De ruijter replied 10 years, 5 months ago 1 Member · 2 Replies
  • Ruud De ruijter
    April 11, 2016 at 1:29 pm
    Okay, but I am not sure if there will come sound if I render it in after effects. What I do in premiere pro is just importing the adobe after effects project and then I can select what I want to import and then I select comp1, which is the visualiser+music.
  • Ruud De ruijter
    April 12, 2016 at 7:04 pm
    Okay I’ll do that.
