Activity Forums Adobe After Effects Cosmic zoom…any tutorials available?…i’ve searched and not found any…
  • Cosmic zoom…any tutorials available?…i’ve searched and not found any…
    Posted by Nrwalker on February 3, 2007 at 5:55 am
    We would like to use this effect in our new short film. This is done really well today. We need to start close-up on somebody and slowly, steadily zoom out away from person, then back out through wall of house to reveal house, then reveal neighborhood, then city, then USA, through clouds and then into space.
    What’s the best way to seamlessly create this effect with the quality that is seen today in a lot of commercials and films ?
    i was told I could find information on how to do this here but i have searched and not found anything that relates specifically to this.
    thanks
    Nathan
    Nashville, TN
    Andy Burmeister replied 19 years, 6 months ago 3 Members · 2 Replies
  • Antony Buonomo
    February 3, 2007 at 2:30 pm
    Yes, it’s relatively easy to achieve this effect to a good standard. However, the quality of the effect depends almost completely on the quality of the footage/stills that you obtain. There are many ways a good graphic artist can use AE to enhance decent footage, but there is no way crappy footage can be made to look like high-end commercial work.
    Break down the shot you want; from beginning to end, then get the very best material you can for every stage. If you want to start on a person, is it footage or a still? If footage, is it real or from an animation packsge? Does the footage contain a zoom or will you have to do it in AE? Questions like this all the way through your sequence will give you the best results your budget/time allows. Be warned, if you want high-end results it will cost you. There is no way around this. I am constantly amazed (nothing personal; not aimed at you) at how some people expect the same quality they see in big-budget work but done on the cheap. Just doesn’t happen.
    Good luck and let us know how you get on.
  • Andy Burmeister
    February 8, 2007 at 4:34 pm
