Activity Forums Apple Final Cut Pro Legacy Corrupted transitions
  • Corrupted transitions
    Posted by Paolo Drusi on March 2, 2014 at 8:46 am
    I’m editing the following sequence
    1920×1080
    Compressor H.264
    and when I export it as QT movie using
    Apple ProRes 422 (HQ) 1920×1080 30p 48kHz
    the video looks good but all the transitions (mainly cross) look corrupted. For example in some I can see a flash, in others strange skipping frames.
    Any ideas why?
    Thank you
    P
    John Fishback
    replied 12 years, 6 months ago
    3 Members · 4 Replies
  • John Fishback
    March 2, 2014 at 2:31 pm
    If you edited with H.264 media in FCP, that is probably the reason. H.264 is not an edit format in FCP. You should convert to ProRes before the edit. Try that with one or two clips and see how the transitions look.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Paolo Drusi
    March 2, 2014 at 3:02 pm
    Yeah John, I suspected that as I had other troubles.
    I’ll give it a go. Thank you so much!
    p
  • Paolo Drusi
    March 2, 2014 at 3:03 pm
    BTW, best way to convert from H264 to ProRes?
    Thank you
    p
  • John Fishback
    March 2, 2014 at 7:07 pm
    I usually use Compressor, but MPEG Streamclip also gives good results. I have Sorenson Squeeze 9, but have never tried it for this. I suspect it’d do a good job, too.
    John
