Activity › Forums › Adobe After Effects › corrupted PNG image sequence
Posted by Peter Stenhouse on September 4, 2008 at 10:57 amHi there. I am using some image sequences delivered by a client. Some of the images are corrupted and crash aftereffects and the render. Is there any technique or software that could quickly identify which of the files is corrupted. So far I have been simply stepping through frame by frame and making note when AE crashes or displays an error report. As you can probably imagine, this is a painful and time consuming task.
Any suggestions would be welcome, sincerely
PeterPeter Stenhouse replied 18 years ago 2 Members · 3 Replies -
Joseph W. bourke
September 4, 2008 at 2:00 pmHi Peter –
Are you sure that it is a corrupted image that is causing the problem? Single image sequences are one of the most bullet-proof ways to get an animation into AE. Is it possible that your memory settings are causing the crash?
There is a “secret setting” in AE’s preferences which allows you to purge memory after a certain number of frames. When you’re in AE, hold down the SHIFT key and select Preferences. You will see a new menu that allows you to purge memory after “x” frames. I set mine to every 5 frames, and haven’t had a crash since.
Another thing to check is the size of the actual .png files. Are they 720 x 480 or another video standard size? If not, the conversion in AE may be hogging memory as well. You could do a batch size in Photoshop and run it on the folder that holds your .png files.
If neither of these is the culprit, check here:
https://generalspecialist.com/2007/02/troubleshooting-after-effects-7.asp
If it really is corrupt frames, just what you have been doing is the correct process. You will have to isolate which frames are causing the problem, then have your client (maybe ex-client after this nightmare!) re-output them. Good luck!
Joe Bourke
Art Director / WMUR-TV -
Joseph W. bourke
September 4, 2008 at 2:01 pmHi Peter –
Joe Bourke
Peter Stenhouse
September 4, 2008 at 2:32 pmThanks for the advice. Unfortunately the files are corrupt rather than being a memory problem.
I have had very few problems with image sequences till now.
I found the best way to detect them was to drag the entire sequence into preview, which will throw up a error message specifying images which won’t load. Scanning the thumbnails will also show which images are recognized as PNGs but are incomplete, i.e, half black.
so yeah
Painful, time consuming,thanks again
Sincerely
Petersmall flowers crack concrete
