Activity Forums Adobe After Effects Corrupted export from media encoder
  • Corrupted export from media encoder
    Posted by Florencia Handler on July 31, 2025 at 2:32 pm
    Hi. Some videos edited in After Effects 25.3.2 (build 2) and exported with Media Encoder 25.3 (Compilation 73) are corrupted. Does anyone know if there is a bug or something like that? Thanks.
    Mads Nybo jørgensen
    replied 1 year ago
    3 Members · 7 Replies
  • 7 Replies
  • John Martin
    July 31, 2025 at 2:50 pm
    define “corrupted”. Are the files unopenable or do they open but have partial glitches?
    August 1, 2025 at 5:07 am
    Hey Florencia,
    Adobe v25.3, certainly for Premiere Pro, is one big bug.
    If you can, roll back to an earlier version like v25.0 and see what happens.
  • Florencia Handler
    August 1, 2025 at 11:54 am
    Yes! Corrupted is with glitches like “blinds” and others are like small lines with dead piexls, so to speak (I don’t have any example of this)
  • Florencia Handler
    August 1, 2025 at 12:01 pm
  • Florencia Handler
    August 1, 2025 at 12:10 pm
    Yes, I’ll try that. Thank you, Mads!
  • Florencia Handler
    August 1, 2025 at 12:12 pm
    They have partial glitches. Like short lines of dead pixels (I guess) or something like blinds
    August 2, 2025 at 6:16 pm
    Hey Florencia,
    If you render out the same AE composition twice, do the glitches appear on the exact same frame(s)?
    Maybe also test using different codecs for your destination master video file.
    But if always at the same place, it is likely to be “rogue” key-frames, or damaged footage (if video – would need to get more information of the sources in the composition).
    Less likely, but could also be a plug-in that is playing up.
    Hope that this helps?
    mads
