Activity › Forums › Avid Media Composer › Corrupted DNXHD file, need to repair!!
  • Corrupted DNXHD file, need to repair!!
    Posted by Ryan Northcott on November 9, 2015 at 4:40 pm
    Hey guys, first post here and it’s a problem. I was filming over the weekend for our doc series on a C100 mk1 and Ninja Blade set to DNXHD 220x. Everything was going just fine until I brought the files over into Avid and they wouldn’t link. Getting a ‘corrupted file’ error. So I open up the files in VLC, and lo and behold I am getting some very strange horizontal colour artifacts. Almost like a bad record head look on a tape, but very colourful and obviously a digital corruption. It just keeps getting worse and worse as the clip progresses as well.
    I absolutely need this footage to work, has anyone seen anything like this or have any idea if it is repairable? The footage is indeed there (according to VLC), but I can’t get it to actually play back on any of our NLE’s.
    Pic is attached, check it out.
    Thank you
    Ryan Northcott replied 10 years, 10 months ago 2 Members · 2 Replies
  • Robert Ober
    November 10, 2015 at 9:47 pm
    Are the camera originals OK? Assuming you are working off of copies, I would open the camera originals in Resolve and see what they look like.
    Hope you fix the issue,
    Robert
    Robert A. Ober
    IT Consultant, Vidcaster, & Freelancer
    http://www.infohou.com
    Houston, TX
  • Ryan Northcott
    November 10, 2015 at 9:49 pm
    Stupidly I did not record internally as everything seemed to be functioning fine. The C100 is crippled by such a low bitrate that we use DNxHD files from the Ninja pretty much exclusively.
