Activity Forums Audio Corrupt WAV file recovery
  • Ty Ford
    July 29, 2014 at 4:37 pm
    Hi Pete,
    Great post! Thanks for stopping by!
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • John Monroe
    August 9, 2014 at 12:28 pm
    great solution however my corrupted files are in m4a format and i have no way to convert them to WAV or another audacity compatible format
  • Josh Smeal
    April 11, 2015 at 11:53 am
    I wasn’t sure if anyone had suggested anything for your issue with the m4a format, if you happen to have , perhaps give it a go with your file. I have never tried to convert m4a to anything else, personally, but I’d be interested to know if this works for you. Cheers!
  • Joe Bressler
    September 14, 2015 at 2:22 am
    Hey All
    I’m in a similar situation- corrupt file because of battery depletion during recording. In fact, I had pressed the stop button and the moment I did, the zoom powered off.
    What I have now is a 372MB file that opens in VLC with a duration of 35:08, however it only has audio for about 25 minutes of this. I also can’t export the full length of the file from VLC because at 25 minutes it says File reading failed/VLC could not read the file (m). When importing as raw data to audacity once again all I get is the first 25 minutes, except this time it is at 200% speed.
    Anyone have any ideas as to if I can recover the last ten minutes?
  • Ty Ford
    September 14, 2015 at 10:58 am
    Hello Joe,
    you know you can change the sample rate on audacity to make it play at the proper speed, right?
    Regards,
    Ty Ford
  • Joe Bressler
    September 14, 2015 at 12:28 pm
    Hey Ty
    Yep, got it. Any thoughts on being able to recover the last ten minutes of this audio file if it’s not already coming up in audacity when I import the raw data?
    The duration in VLC being correct gives me some hope as well as the fact that it isn’t a 0kb file
  • Bouke Vahl
    September 14, 2015 at 12:37 pm
    The duration of VLC might be meaningless.
    What are you feeding VLC?
    To know if you can recover it, you need to calculate the duration based on file size…
    hth,
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Joe Bressler
    September 14, 2015 at 1:05 pm
    Hey Bouke,
    I am feeding VLC the wav file straight from the SD card. The file size is 372mb vs a 35:08 duration. When I export the file from audacity or VLC it’s about 100mb less, a loss of which seems proportionate to the amount of data that should account for the missing audio.
Page 3 of 3
