Activity Forums Apple Motion Corrupt renders in Motion
  • Corrupt renders in Motion
    Posted by Mike Jackson on June 12, 2007 at 6:43 pm
    I’m usually an After Effects guy, but with a tight deadline upon me I thought I’d try round-tripping from Final Cut to Motion now that I have FCP Studio 2.
    I’m doing a split-screen with a complicated matte. Everything seemed to work fine, but my renders end out corrupted if I use anything other than 8-bit depth. At 16-bit I get bright green blocky pixels in the shadows of one half of the image. If I use 32-bit floating-point that same side starts to blink on and off, and the other side turns into tight flickering horizontal lines.
    Any clues, hints or advice? Is the new motion just busted?
    Original footage is DVCProHD, but the corruption happens whether I render in DVCPro or the new ProRes codec, and whether I render in Motion or FCP. Dual 2.7 G5 with 2.5 Gigs RAM, ATI Radeon 9650.
    Mike Jackson replied 19 years, 2 months ago 2 Members · 2 Replies
  • Noah Kadner
    June 13, 2007 at 4:57 pm
    Can you post a few stills? That sounds like a possible issue with your graphics card.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Mike Jackson
    June 15, 2007 at 8:24 pm
    I’ve posted some frames here:
    https://www.steampoweredfilms.ca/Temp/BadRenders.htm
    Ironically, Color seems to be able to handle my graphics card just fine.
    Using graphics cards for acceleration seems like a great idea in theory, but it adds so much more of a crap-shoot to every task, depending on your hardware. I’d kill for a button to force a render to work through the CPU, regardless of how long it takes, if it meant consistent, reliable results.
