  • Posted by Kevin on May 1, 2007 at 3:51 am
    Hi list. I recently had to recovery data from a raid I wiped by mistakae. I used Data Rescue11 and it’s works well overall but some .movs play fine. Others won’t open. I guess there’s ome curruption. Would anyone have any ideas on a fix for these files are are they kaput.
    Many thanks,
    Kevin
    David Roth weiss replied 19 years, 4 months ago 3 Members · 2 Replies
  • 13 Create COW Profile Image
    13
    May 1, 2007 at 3:58 am
    Most likely it could only recover part of the file, and there is no way to fix a file like that.
  • David Roth weiss
    May 1, 2007 at 5:11 am
    In these cases only the header information is recovered. Unfortunately you are probably out of luck.
