Activity Forums Apple Final Cut Pro Legacy Corrupt Project! Heeeelp!
  • Corrupt Project! Heeeelp!
    Posted by Zeliha Bozkurt on June 27, 2007 at 3:45 pm
    Hi I had crash and when I tried to open my project I get the below message
    “This project is unreadable or may be too new for this version of final cut”
    I think my project is corrupted. I cant even open it. It loads upto 40% but then stops giving the above message.
    Does anybody know how to fix this.
    PS: I have disconnected all my drives and try to lauch the project but same thing happened.
    Zee.
    Randolph Harrison replied 19 years, 2 months ago 4 Members · 4 Replies
  • Cpdurham
    June 27, 2007 at 3:48 pm
    Hopefully you have Autosave enabled? I’ve had this happen in the past once or twice; opening your most recently Autosaved project file should work fine.
    The only other thing I can suggest is to copy the project to a different drive; I’ve had this work sometimes.
  • Zeliha Bozkurt
    June 27, 2007 at 4:12 pm
    I tried that all the autosave projects from 12.30 onwards are corrupt too.
    I tried o open the project on two other systems but still didn’t work.
    Dont know what to do now 🙁
    Zee
  • John Pale
    June 27, 2007 at 4:15 pm
    e-mail me the project.
    I like a good puzzle.
    pale DOT edit AT mac.com
  • Randolph Harrison
    June 27, 2007 at 7:20 pm
    Hi Zee,
    I seem to have this same problem about once a week.
    Sometimes I will try restarting the computer with the external drives off, then turn them on. If this doesn’t work, I will trash the FCP preferences, launch the project and then reset my preferences in FCP.
    Re: autosave vault… if you are able to open the project from a previously saved autosave file, be sure and “save your project as” once you open it. Otherwise I have found myself with two projects with the same name.
    Hope this helps,
    Randy
