Activity Forums Apple Final Cut Pro Legacy Corrupt project file
  • Corrupt project file
    Posted by Justin Heaney on April 2, 2009 at 10:34 am
    Hi there guys.
    I have been editing a project for 3 years, and have just lost 3 months of the work due to swapping a file between FCP 4.5 on PANTHER & FCP6 on LEOPARD.
    The file was created under FCP 4.5 on PANTHER, and successfully opened and SAVED on FCP6 on LEOPARD.
    Then by mistake some changes were made under FCP 4.5 again, now the thing wont open anyway (autosave files deleted)
    Is there anyway that anyone here could edit the FCP file in text edit or something to make it work.
    Any help would be incredible!
    Justin
    Arnie Schlissel replied 17 years, 5 months ago 3 Members · 5 Replies
  • Justin Heaney
    April 2, 2009 at 11:21 am
    Is someone able to possibly open up my project file save as & and return it to me?
    Justin
  • Victor Perez
    April 2, 2009 at 2:33 pm
    Have you tried opening the project from the AUTOSAVE VAULT? I’m sure you already know this, if you update your project to FCP 6 it will no longer open in FCP 4.
    Sounds like you have FCP 4 & 6 loaded on your machine? or are you working between 2 machines?
    Victor
  • Justin Heaney
    April 2, 2009 at 11:12 pm
    Have FCP 4.5 on Panther & FCP 6.0 on Leopard.
    I knew by bringing the project into 6.0, that I would lose backwward compatability, but now it wont even open in 6.0.
    Any help would be appreciated
    (Can send Zipped file)
    Justin
  • Justin Heaney
    April 3, 2009 at 2:32 am
    Issue solved!
    For the records:
    A very helpful posthouse in Hollywood opened my project on FCP 6.0.3 and exported XML for both FCP4.5 & FCP 6.0
    Worked like a charm! (just needed to relink media)
    The POWER of community!
    Justin
  • Arnie Schlissel
    April 3, 2009 at 4:28 am
    Why do you not have a backup? Do you not backup your Mac on a regular basis? Do you not keep backup copies of things that are important to you?
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
