Activity Forums Adobe Premiere Pro Corrupt Premiere project – xml wrench still a thing?
  • Corrupt Premiere project – xml wrench still a thing?
    Posted by Alex Ezorsky on June 8, 2019 at 12:03 pm
    Working on windows 10 surface book 2 and Premiere 2019 v13.1 using an external SSD drive formatted in exfat
    In order to edit while on a trip I transferred my project folder to an external ssd drive from my desktop pc and worked on the project via my laptop for a week. Everything worked fine all week, I get back and all the project files I worked on AND their autosaves give me a “project appears to be damaged and cannot be opened” error. Now whats super strange is that any autosaves that were originally transferred to the SSD from BEFORE I started using my laptop are fine and can be opened on my laptop. The project files I made while on the trip are the only ones that seem corrupted and yet they still have normal file sizes and extensions and otherwise look fine.
    Failed troubleshooting attempts:
    – Opening on desktop
    – Transferring project file only to new folder
    – checking the drive letter is the same
    – Importing into new project – “project could not be opened”
    – Importing into After Effects – “project could not be opened”
    – Trashing preferences
    I wanted to try the XML wrench method but opening any project file, be that my working projects or corrupt projects, into XML wrench either with our without re-naming the file extension from prproj to xml just returns ‹ so there must be something I’m doing wrong or else this method does not work for modern versions of PR. I guess this is where I’m asking for most help, unless someone has any other suggestions in general.
    My best guesses as to what happened:
    I unplugged the drive strangely and corrupted some data
    Somehow everything I did on the SSD was “writing” in a slightly weird way and when I got back and the data corruption only altered those files.
    This makes sense because the videos I exported during the trip are also giving me corruption errors upon import (but also have normal filesizes)
    Lucas afonso Tonezer replied 7 years ago 3 Members · 2 Replies
  • Nina Lucia
    June 11, 2019 at 5:21 pm
    Look, I really don’t know Premiere, but are you using the same software version on both the laptop and desktop? Or is the laptop a newer version? I had to ‘downgrade’ a project I got from 2019 to 2018 and I think I got that message at some point before I did that.
    Then again I could be completely wrong! Just spitballing until someone else comes along with a solution…
  • Lucas afonso Tonezer
    September 2, 2019 at 2:29 pm
    Hey, did you discover how to repair the xml file? I’m having the same issue, xmlwrench says that have a problem on line 1, but the line 1 is: ‹.
