Activity › Forums › ARRI › Corrupt .mov after battery died
  • Corrupt .mov after battery died
    Posted by Sarah Bright on May 31, 2015 at 12:52 pm
    Hi all,
    I’m out on a shoot at the moment as the edit assistant and we’ve had some issues with the Arri.
    First off, yesterday the battery was knocked out mid shoot which corrupt the one file that they ere filming at the time.
    Today, the battery died mid filming which is now having the same issue with the clip they were filming.
    The clips still play up until about 30 seconds until the end, so I think they are salvageable.
    Have any of you had this issue?
    Also, my main problem is that the one problem clip won’t copy off the card to a hard drive.
    I’ve tried using ShotPut Pro, 2 different card readers, copying at finder level and I can’t get Terminal to copy either.
    Is there another way to copy this off that I’ve not tried or do you have any tips?
    We really need this footage so any help you can give me to save it would be really appreciated.
    thank you!
    Sarah Bright replied 11 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
