Activity › Forums › Avid Media Composer › corrupt .mdb (database) file
Posted by Dave Stalker on August 11, 2011 at 3:31 pmWe are editing on MC2.6 on HP XW8400 Workstations w/ 3GB Ram, Windows XP Pro 2002, Intel Xeon CPU 5150 @2.66GHz.
Clips on the timeline have started to disappear after an export process crashes and when re-launching software error message indicates that the database that handles the .mxf files is corrupt.
The problem has spread from the original project it occurred with and is now affecting other projects opened on this system. Clips that were playing suddenly show up as media offline.
What are the options? If we simply delte the corrupt .mdb file will we lose access to all the media in the projects? This is a commercial project shot at one facility and brought to us to post on deadline, so losing the entire thing would be very bad.
Any suggestions appreciated.
Brent Marginet replied 9 years, 2 months ago 12 Members · 11 Replies -
Shane Ross
August 11, 2011 at 4:24 pmJust delete the files. Avid will rebuild them. That is actually a trick Assistants use to keep things organized and current. Avid always looks at them, and at the media, always checking. Add media on the finder level (or…desktop level), and Avid says “hey, there’s more things here,” and updates the file.
Just quit Avid MC, delete the databases, and launch Avid again. And it will rebuild…and take a while depending on how much footage you have.
Shane
Read my blog, Little Frog in High Def -
Alex Krenvalk
September 6, 2011 at 6:48 pmFor working out present condition you may use recovery for access. It has many various features such as working under all popular Windows OS, using modern methods of recovering mdb data. The tool doesn’t modify source access data during restoration.
Stefan Mendel
November 16, 2011 at 10:58 amHi,
This is advance solution to recover corrupt .mdb files instantly and without any data loss. few days ago i was in trouble due to .mdb corrupt. My one of friend told me about Access Recovery Tool which is design by SysTool Group. I was try it and this software recovery .MDB corrupted files instantly. it can recover password protected files as well. May be this will help you just try it to download click this link https://www.accessdatabaserecovery.org/
Hopefully this will help you!
Stefan -
Marry Wilson
June 5, 2012 at 12:28 pmAccess database contains various records in the form of tables which are accessed by the users to retrieve information. The MDB files or the Access database files may get corrupted or damaged due to various defined or unfamiliar reasons. When such corruption occurs in Access database then recovery tool needs to be used to repair the MDB files and retrieve the database. Once i used Kernel for access repair tool which retrieved all my data from a corrupted .mdb file instantly.
for more information – https://www.accessrecoverytool.net -
Allen Smith
July 4, 2012 at 10:01 amUser can download the evaluation copy of RecoveryFix for access repair free of cost from https://www.repairaccess.net/ . The free version works similarly the paid version. The only difference is that free program does not allow the user to save the recovered items, which is possible only with the licensed version of access database repair program. The software supports all versions of MS Access and Microsoft Window. You can also use this tool to recover data from the password protected Access database file, in case you know the password of the specific file.
Naitik Semwaal
August 28, 2012 at 7:31 amMDB or MS Access database file can be corrupted at any point of time due to numerous factors which have ability to corrupt critical data. A corrupt .mdb file can’t be accessed anymore, hence it becomes useless. But if have a valid and regular backup for that .mdb file then we can easily restore it from that backup. But if not then three things can be done to deal with this situation:
- Try to import the data of corrupt .mdb into a new database file. And see if it gets opened or not.
- Use Compact and Repair Utility for MS Access database. It is absolutely free but sometimes it does not work with heavy corruption. But still it is mostly recommended.
- If both above solutions don’t work, that point of time a file repair application provided by various software companies would be the best answer.
MDB file repair fixes the heavy corruption from .mdb files and makes them reusable in just no time. This application is very safe and highly effective.
Ramend Lonk
April 18, 2014 at 10:16 amYou can try any one:
1. Compact and Repair
2. Import damage database to a new oneIf you have no thought how to do that, you may read this article : https://msofficerecovery.blogspot.com/2014/04/resolving-errors-after-access-database-corrupts.html
Herb Ritts
April 28, 2014 at 12:35 pmRecoveryFix for access file recovery utility is trustfully utility to restore your lost and damaged mdb files. You can download this utility to restore your lost files. For more details: https://www.recovery.openmdbfile.net/
To know more read this blog: https://diskdatarecovery.jimdo.com/2011/11/30/resolving-disk-i-0-error-during-read-while-working-with-ms-access/
Job Ter burg
May 2, 2017 at 9:45 pmWhole bunch of spam from database recovery tool fans, I guess, but that makes no sense at all. A corrupt media database is not a problem in MC. Simply trash the file (or move it to another location outside of the mediafiles folder), and MC _will_ rebuild the files. As long as no actual mediafiles themselves are corrupt, this rebuild has zero consequences, other than refreshing the database that tells MC where each file currently lives.
No-brainer. Don’t mess with repair tools on Avid media databases. -
John Walker
July 4, 2017 at 9:46 amtake a look at this link, it will show you 5 different method to repair corrupt .mdb file: https://www.repaircrashed.com/ms-access/
