Corrupt File
Hello everyone,
I recently purchased the HPX-250 and took it with me to Afghanistan this past month for a documentary. The camera performed very well, as I would expect having used the HVX-200 these last few years.
Corrupt file problem:
One of my card reels downloaded to an external hard drive via MacBook Pro would not by copied to another hard drive due to a “corrupt” clip. I opened the clip in Log and Transfer in FCP and a few seconds into the shot, the image would stutter and jump to the end of the clip after a moment of processing.
Is there a solution to repair this clip? Otherwise, I believe my only option to backup this footage is to delete the original MXF clip from the Contents folder. Thoughts? (I would rather not delete the shot.)
Thank you for your advice,
-FRANK
