Activity Forums Apple Final Cut Pro Corrupt Events
  • Corrupt Events
    Posted by Jim Waterwash on June 19, 2012 at 4:54 pm
    I’m trying to diagnose why my FCPX system is so slow and why Projects are becoming corrupt and I suspect that it is because my event is corrupt. I had created this event back in January and now when I look at it, it has 12 clips in the event that show “null”.
    Has anyone ever seen such a thing within their events?
    When I recently loaded the event into FCPX (I use Event Manager X) it told me that it had to upgrade the event for the new version of FCPX. It’s been 2 or 3 minor versions since January. I am concerned that the reformatting process that FCPX did on the existing Event is responsible for the corruption. These “null” entries seen within the image, are appearing on 2 separate events. In one of them, I just deleted them, but I still am having problems where projects created with the event, are slow and getting corrupt.
    I have 2 more Events that I am afraid to unhide from FCPX, in fear that it will corrupt them as well. I’m already a week behind on this project and am thinking of giving up on FCPX. Obviously this will set me back another week. Because it’s happening with 2 separate events, I’ve so far avoided spending $108 on diskwarrior.
    I’m just curious if others have run into these “null” entries or have had issues with upgrading event databases. Also, ss there any application that can be run to verify the integrity of an Events database?
    T. Payton replied 14 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • T. Payton
    June 19, 2012 at 8:43 pm
    Jim,
    Major bummer. Yes i have seen this with a fellow in Europe with 10.0.1. Are the blank clips ones that you are using or did they just appear?
    Don’t give up on FCP X yet. Unfortunately corruption is a part of life (I’ve lost all sorts of Final Cut, After Effects, and InDesign files over the years). I personally haven’t had any corrupt events or projects in FCP X, so know that there is hope here.
    So here is a page that might be helpful:
    https://fcpx.tv/troubleshooting.html
    Based on what is happening with your blank clips I would try this:
    1- Export your event as an FCPXML and then reimport. I have seen doing that fix a lot of problems. If that doesn’t remove the blank entries at first, you might even want to look at the XML file to see if you see any blank entries. (However, if you are using compound clips to edit some of the info might be lost (like key framing) so in then that might be a problem and you’ll want instead to do #2.
    2 – Copy to a new event by option-dragging your clips to a new event. Everything will be retained in your new event except folders (at least in my tests). Be sure to test with a few clips first before you drag the whole thing.
    After you do #1 or #2, disable your old corrupted event and upon the next launch FCP X should find all the footage. You might need to change the event references for the projects.
    3 -Now if you are still stuck after trying #1 or #2, I would give Apple a call. It will take some time and they can help.
    4 – if you are still stuck after 1, 2, and 3, I’ll be glad to help as best I can. We could screen share or whatever.
    Hang in there.
    T. Payton
    OneCreative, Albuquerque
  • Jim Waterwash
    June 19, 2012 at 11:28 pm
    It worked! Thanks for your help.
    Step #1 (exporting and reimporting the event’s xml seems to have done it.
    I can now just select all my keywords and add them to a new project all at once. Before, when I would select a single keyword segment, after adding one to a project, it would take a minute or two of spinning beach balls before I could even use FCPX. Selecting more then about 3 and adding them would hang FCPX.
    Thanks again.
    Jim
  • T. Payton
    June 19, 2012 at 11:30 pm
    Jim,
    Glad to hear it!
    – T.
    T. Payton
  • Jim Waterwash
    June 20, 2012 at 6:09 am
    So while those empty entries within my events was a suspect cause for some of my problems, I believe there is most probably a bug involving Event Keywords that have overlapping regions.
    I have a region named “interview” within my event, whose region contains multiple keywords defining sub regions. I believe this is what is confusing FCPX.
    While it is possible for me to now select all the keywords in the event browser’s list view and add them to a project, the resulting keywords that make it into the project are a bit scrambled around these overlapping keywords. This may be the cause for the project still taking over a minute to load (and I have the events and projects on an SSD now).
    I just wanted to provide more details so the bug can be verified, avoided, or maybe even fixed..
  • T. Payton
    June 20, 2012 at 3:26 pm
    Jim,
    I haven’t seen any problems with overlapping regions on my end. I would duplicate that clip, clear all the keywords from it and then try to reapply the keywords and see if it still happens.
    Also, while I love to hear about the problems, report them directly to the FCP team where they will be logged and addressed.
    https://www.apple.com/feedback/finalcutpro.html
    The best way to do that is find a way to reproduce it and then report it with details like this:
    1. Summary of issues
    2. Steps to reproduce the issue
    3. Expected Results/Actual Results
    4. Any additional details.
    T. Payton
  • Ted Irving
    June 21, 2012 at 2:32 am
    I’ve been using FCPX since 10.0 and its been smooth sailing til now. I’m getting hammered. Something is corrupted and I’ve narrowed it down to two projects I have in one event. I’m using event manager and preferences manager for FCPX 10.04 and my Final cut will only launch and immediately crash after all windows appear. Been happening since yesterday. I’ve copied event & project files, ken stone fcpx tips, etc. nothing. And i’m on a deadline. Some of the error code is pasted below. There has to be some type of way to get these project (timelines) back and preventing them from causing FCPX to crash/quit.
    _______________________________________________
    Process: Final Cut Pro [8109]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCut
    Version: 10.0.4 (197051)
    Build Info: ProEditor-197050125~3
    App Item ID: 424389933
    App External ID: 7274436
    Code Type: X86-64 (Native)
    Parent Process: launchd [214]
    Date/Time: 2012-06-20 21:18:20.452 -0500
    OS Version: Mac OS X 10.7.4 (11E53)
    Report Version: 9
    Interval Since Last Report: 79474 sec
    Crashes Since Last Report: 39
    Per-App Interval Since Last Report: 3288 sec
    Per-App Crashes Since Last Report: 38
    Anonymous UUID: 78B6A4FA-571D-4F93-9CCB-4C876A36F1C0
    Crashed Thread: 20 BGTask: MEBackgroundLoadManager Dispatch queue: com.apple.root.default-priority
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000010
    VM Regions Near 0x10:
    __TEXT 0000000100000000-00000001000cb000 [ 812K] r-x/rwx SM=COW /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Application Specific Information:
    objc[8109]: garbage collection is OFF
    Thread 0:: Dispatch queue: com.apple.main-thread
    0 libsystem_kernel.dylib 0x00007fff83b3667a mach_msg_trap + 10
    1 libsystem_kernel.dylib 0x00007fff83b35d71 mach_msg + 73
    2 com.apple.CoreFoundation 0x00007fff8db0750c __CFRunLoopServiceMachPort + 188
    3 com.apple.CoreFoundation 0x00007fff8db0fc74 __CFRunLoopRun + 1204
    4 com.apple.CoreFoundation 0x00007fff8db0f486 CFRunLoopRunSpecific + 230
    5 com.apple.AppKit 0x00007fff8724e49c -[NSMoveHelper _doAnimation] + 1399
    6 com.apple.AppKit 0x00007fff8710a214 -[
    0x7fff85400000 – 0x7fff85447ff7 com.apple.CoreMedia (1.0 – 705.78) /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff85448000 – 0x7fff854b3ff7 com.apple.framework.IOKit (2.0 – ???) <6C604894-7F61-3130-8499-20791D14577F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff854b4000 – 0x7fff854b6fff com.apple.EFILogin (1.0 – 1) <71D23C08-890D-34B7-B85D-B7F967090FA6> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff854b7000 – 0x7fff85c4bfef com.apple.CoreAUC (6.16.11 – 6.16.11) <3D40FEA5-AFE7-3752-A52E-D0F80304320A> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff85c4c000 – 0x7fff85c92fff libcurl.4.dylib (7.0.0 – compatibility 7.0.0) <2C442396-1006-3765-92D2-60869D4641CE> /usr/lib/libcurl.4.dylib
    0x7fff85c93000 – 0x7fff85ca0ff7 libbz2.1.0.dylib (1.0.5 – compatibility 1.0.0) <8EDE3492-D916-37B2-A066-3E0F054411FD> /usr/lib/libbz2.1.0.dylib
    0x7fff85ca1000 – 0x7fff85d24fef com.apple.Metadata (10.7.0 – 627.32) <38735923-2EB5-3133-BE36-BDD65A7E47DB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff85d25000 – 0x7fff85d2ffff libcsfde.dylib (??? – ???) <4E8CF39C-
    VM Region Summary:
    ReadOnly portion of Libraries: Total=356.9M resident=178.0M(50%) swapped_out_or_unallocated=178.9M(50%)
    Writable regions: Total=1.4G written=442.9M(31%) resident=593.6M(42%) swapped_out=0K(0%) unallocated=819.5M(58%)
    REGION TYPE VIRTUAL
    ATS (font support) 33.0M
    CG backing stores 17.3M
    CG image 20K
    CG raster data 3580K
    CG shared images 3432K
    CoreAnimation 35.7M
    CoreGraphics 16K
    CoreImage 72K
    CoreServices 1192K
    IOKit 116.0M
    IOKit (reserved) 519.1M reserved VM address space (unallocated)
    MALLOC 579.6M
    MALLOC guard page 32K
    MALLOC_LARGE (reserved) 19.4M reserved VM address space (unallocated)
    Memory tag=240 8K
    Memory tag=241 8K
    Memory tag=242 12K
    Memory tag=249 264K
    Memory tag=251 120K
    OpenCL 28K
    OpenGL GLSL 1372K
    OpenGL GLSL (reserved) 128K reserved VM address space (unallocated)
    SQLite page cache 8832K
    STACK GUARD 56.3M
    Stack 42.1M
    VM_ALLOCATE 20.5M
    __CI_BITMAP 80K
    __DATA 42.5M
    __IMAGE 528K
    __LINKEDIT 75.5M
    __RC_CAMERAS 248K
    __TEXT 281.4M
    __UNICODE 544K
    mapped file 194.7M
    shared memory 18.2M
    TOTAL 2.0G
    TOTAL, minus reserved VM space 1.5G
    Model: MacPro5,1, BootROM MP51.007F.B03, 4 processors, Quad-Core Intel Xeon, 2.8 GHz, 20 GB, SMC 1.39f11
    Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MB
    Memory Module: DIMM 1, 8 GB, DDR3, 1066 MHz, 0x8502, 0x505344333847313333333200000000000000
    Memory Module: DIMM 2, 4 GB, DDR3 ECC, 1066 MHz, 0x8319, 0x535044303032302020202020202020202020
    Memory Module: DIMM 3, 4 GB, DDR3 ECC, 1066 MHz, 0x8319, 0x535044303032302020202020202020202020
    Memory Module: DIMM 4, 4 GB, DDR3 ECC, 1066 MHz, 0x0D9B, 0x000000000000000000000000000000000000
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.198.4.20)
    Bluetooth: Version 4.0.5f11, 2 service, 18 devices, 1 incoming serial ports
    Network Service: Ethernet 2, Ethernet, en1
    Network Service: AirPort, AirPort, en2
    PCI Card: pci1103,622, sppci_raid, Slot-3
    PCI Card: pci1b4b,91a4, sppci_ide, Slot-3
    PCI Card: ATI Radeon HD 5770, sppci_displaycontroller, Slot-1
    PCI Card: pci1095,3132, sppci_othermassstorage, Slot-2
    Serial ATA Device: HL-DT-ST BD-RE WH10LS30
    Serial ATA Device: HL-DT-ST DVDRAM GH22LS40
    Serial ATA Device: WDC WD1001FALS-41Y6A0, 1 TB
    Serial ATA Device: SAMSUNG HD753LJ, 750.16 GB
    Serial ATA Device: Hitachi HDS721010CLA332, 1 TB
    Serial ATA Device: ST3250823AS, 250.06 GB
    SCSI Device: SCSI Target Device @ 5
    SCSI Device: SCSI Target Device @ 6
    SCSI Device: SCSI Target Device @ 7
    SCSI Device: SCSI Target Device @ 8
    SCSI Device: SCSI Target Device @ 16
    SCSI Device: SCSI Target Device @ 0
    SCSI Device: SCSI Target Device @ 15
    USB Device: iPhone, apple_vendor_id, 0x1294, 0xfa400000 / 3
    USB Device: 3600-4600 Series, 0x043d (Lexmark International Inc.), 0x0142, 0xfa200000 / 2
    USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x5a100000 / 2
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x5a110000 / 5
    USB Device: Hub in Apple Extended USB Keyboard, apple_vendor_id, 0x1003, 0x3d100000 / 2
    USB Device: Apple Extended USB Keyboard, apple_vendor_id, 0x020b, 0x3d130000 / 3
    FireWire Device: built-in_hub, 800mbit_speed
    Ted Irving
    Freelance Content Creation
    CBS MaxPreps/BBN3
    http://www.tedtv.tv
    tedirving@yahoo.com
  • T. Payton
    June 21, 2012 at 4:59 pm
    Ted,
    If you are under deadline, I would definitely give Apple a call. They probably have ways of helping.
    My thought is that you might have a corrupted clip in that event. To test it quit FCP, move all projects and events to disabled and then goto your problem event and put an X in front of the “Original Media”, “Transcoded Media” and “Render Files”. Don’t worry this is harmless, it is just hiding those from FCP X.
    Now see if the event will load. If it does, one of those folders has a corrupt file in it. To troubleshoot go one by one and remove the X (of course only doing that while FCP X is quit).
    If that doesn’t work, post back.
    T. Payton
