Activity Forums Apple Final Cut Pro Legacy corrupt audio
  • Posted by Louis Germano on November 17, 2010 at 3:14 pm
    Been using FCP for about 3 years. I’ve run into this a couple times and I can’t wrap my mind around what is happening. I use a piece of music in a sequence. The music in the sequence does not exactly match the original clip in the bin. Music swells where it should sting for instance. The audio waveform shows sting… the sound plays as a music swell. When matching back to the original media in the source bin, the original media plays the sting. So, it seems like the clip in the sequence is not the clip in the bin. Is it a subclip once it hits the sequence? Is it a QuickTime reference file? Obviously the clip in the sequence has become corrupt in some way, but the original remains intact. (Today the audio clip in the sequence was corrupted and became static, while the match to the original plays the music perfectly).
    PUZZLED
    Lou@aurora
    Cameron Levy replied 14 years, 3 months ago 4 Members · 3 Replies
  • Michael Sacci
    November 18, 2010 at 6:24 pm
    I would never edit with a ref files. For me the only use for a ref file it is use for encoding.
  • Cody Walters
    November 18, 2010 at 10:09 pm
    This has happened to me too. The wave forms are not matching up to the audio I am hearing, and when I look at it in the view and press f to find the original, the music is fine and in its right position.
    What I do is bring in a new audio clip from the original. It is annoying to have to do that, but it solves my problem and I can get back to work.
    It seems to me that this is a bug within Final Cut.
    Cody Walters
    Mac Pro 2.26GHz 8 Core Xeon
    16 GB 1066 MHz DDR3
    Final Cut Studio 3
    Panasonic HVX-200
  • Cameron Levy
    May 14, 2012 at 6:36 pm
    Yes I have this problem not only with wavs but aiff files too, it’s annoying I reviewed an hour long programme and it did I it in four places, the thing is you don’t know where on the timeline it’s going to screw up next, it’s a pain in the a..se! Anyone have any ideas?
