Corrrupt MXF files from C300 camera
Has anyone here had any experience with whole cards shot on the C300 becoming corrupt.
I just had two card backups come back where the clips will play but with severe digital break up. Unfortunately the cards were backed up by the shoot team, not checked and the cards re-initialised so its very hard to tell where the corruption occurred. They were backed up using XF Utility. The file structure seems fine, and the breakup is apparent when viewing with a range of applications. I have encoded the afflicted files to pro-res and they display the same fault. Another card shot that day came back fine. Although interestingly this one was not initialised on the day.
Here is an example screen shot 4622_example.jpg.zip.
I have tried putting the backups back onto a card and seeing if the camera notices the corruption, but it plays back the clips with the same issues. Does anyone have any experience of this? Any suggestions on ways to fix it? I have heard it may be possible to extract the video code from the files, but not had any success with the apps I have tried.
I know that one backup from the card is asking for trouble, but the team were backing up on shoot and rushed our usual double backup protocol in the heat of the moment. It wont happen again. It is however worrying. I dont think its an issue with the cards themselves as they have been used since and been fine, but I am retiring them until I work out what could have caused it. The most worrying thing is it happened to two cards on the same day. One I can put down to freak error, but two …
Any ideas on what could cause the error, and things to try to save the shoot would be greatly appreciated.
