Activity Forums Zaxwerks Correctly importing Illustrator files into Invigorator
  • Correctly importing Illustrator files into Invigorator
    Posted by Jonathan Capra on October 2, 2007 at 10:31 pm
    I’m importing an Illustrator logo but its closing up the hole in my zero and connecting a ‘web’ between the base and the beak of the number one, so it looks like a triangle of sorts.
    Its been a while since I have used 3D Invigorator regularly. I remember there being some way to fix this – either a checkbox in Invigorator or a attributes to set in Illustrator. Anyone got a quick tip?
    I am running AE6.5 with InvigPro 4.x.
    Jon Okerstrom replied 18 years, 11 months ago 2 Members · 1 Reply
  • Jon Okerstrom
    October 3, 2007 at 2:02 am
    Sure thing.
    Look at the doc in Illustrator. Be sure you’ve created a compound path in the zero by selecting the inner and outer path and choosing compound path>make.
    As for the number one, it sounds like you have an open path for some reason. Select the number 1 object and use the pathfinder tool to unite or close the open path.
    Let us know if that helps.
    Jon
