Activity › Forums › VEGAS Pro › Correctly convert AVCHD 60i to DVD settings clarification
  • Correctly convert AVCHD 60i to DVD settings clarification
    Posted by Pete Maschari on June 22, 2010 at 12:49 am
    Hello all,
    I’ve been researching and reading forums all day and am more confused than ever on how to correctly convert AVCHD 1920X1080 60i to DVD in Vegas. First render I setup my project properties with default settings for 1920X1080 60i and render to new track with the default NTSC widescreen DVD Architect setting. When I play it back on my tv, durring fast motion I’m seeing lines.(like when a persons arm moves fast the arm gets all distorted and full of lines). I’m guessing I’ve got some interlacing issue. My understanding is that the AVCHD 60i video from my canon HF100 & HF200s are upper field first interlaced video. Do I need to do any deinterlacing at all to get to DVD? Standard DVD is 480i correct? So I’m going from one interlaced source to an interlaced destination.
    What are the correct settings for “deinterlace method” and “field order” in my project properties AND in my output settings? This is a sports video.
    Thanks for any help.
    John Rofrano replied 16 years, 3 months ago 3 Members · 12 Replies
  • 12 Replies
  • John Rofrano
    June 22, 2010 at 1:15 am
    I’m not sure why you are rendering to a new track but that’s not the way to render for DVD. Just use File | Render As… and select MPEG2 and one of the DVD Architect widescreen templates.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Douglas Spotted eagle
    June 22, 2010 at 3:57 am
    or use VASST DVD Prep script to assure all settings are correct…
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Pete Maschari
    June 22, 2010 at 10:04 pm
    Thanks for the responses guys. I’m still stuck here. The only way I have found to render the video and not get the lines is if I set the feild order to none(progressive) in the render to custom settings. I have read that I’m loosing 1/2 of my resolution by doing it this way though. Leaving everything with the stock HD 1080-60i properties template and DVDA widescreen NTSC template render settings yeild video with lines durring fast motion. I have tried every other combination of field order and deinterlace method all resulting in liney video.
    Please help!!!!!!!!
  • John Rofrano
    June 22, 2010 at 10:25 pm
    It is possible that you action was too fast for 60i and the distance between the interlaced fields is just too much in which case the only solution is to throw half of the fields away. I assume you are viewing the results of the DVD on a physical interlaced TV set?
    ~jr
  • Pete Maschari
    June 22, 2010 at 10:29 pm
    No actually I’m viewing this on a 1080p plasma via a PS3 (also seeing the lines on the computer monitor which I know is also progressive). This dvd needs to work on all setups. SD, HD, interlaced, progressive whatever.
    How would I accomplish this?
  • John Rofrano
    June 22, 2010 at 11:13 pm
    Without seeing what you are seeing it’s difficult to say what’s going on. I can only tell you the correct way to create a DVD from AVCHD-60i. Make sure that you project uses the HD 1080-60i (1920×1080, 29.970 fps) template. Render with the DVD Architect NTSC Widescreen video stream template and the AC3 audio template.
    If you want to render progressive use the DVD Architect 24p NTSC Widescreen video stream template. 24p is only “legal” progressive frame rate for DVD’s.
    ~jr
  • Pete Maschari
    June 22, 2010 at 11:24 pm
    I’ve done exactly that “Make sure that you project uses the HD 1080-60i (1920×1080, 29.970 fps) template. Render with the DVD Architect NTSC Widescreen video stream template and the AC3 audio template” and still get the lines or tears.
    I’ve never seem to have this problem with any other project. Can I email you a sample clip? I really could use some help here.
  • Pete Maschari
    June 22, 2010 at 11:42 pm
    Here is a link to download a 14mb sample
    https://www.sendspace.com/file/pbh2pq
    This was done with the HD 1080-60i (1920×1080, 29.970 fps) template and rendered with the DVD Architect NTSC Widescreen video stream template
    Thanks for any help!
  • John Rofrano
    June 23, 2010 at 12:32 am
    OK, I downloaded your file and there is nothing wrong with it. It’s a typical NTSC Widescreen interlaced MPEG2 file.
    (1) I watched it in Windows media Player and it looked fine.
    (2) I placed it on the Sony Vegas Pro 9.0e timeline and watched the preview and saw the interfaces lines which I expected.
    (3) I dropped it onto DVD Architect and previewed it on the Windows Secondary Monitor and it looked fine
    (4) …and finally I burned it to DVD and watched it on my Samsung Blu-ray player through my Sony HDTV and it looked fine. Not a single interlaced line in sight.
    The only place I saw the interlacing was within Vegas which is expected because you are previewing interlaced video on a progressive display without any de-interlacing.
    I can only assume that either your PS3 does a poor job of deinterlacing DVD’s or it isn’t configured correctly for your progressive display but there is nothing wrong with that footage.
    ~jr
  • Pete Maschari
    June 23, 2010 at 1:04 am
    Wow ok thanks. Interesting. I’m seeing the lines durring fast arm and leg swings when played back in wmp and vlc on the computer and the same on my ps3 and plasma. I have an old DVD player somewhere that I’ll hook up to the plasma and try it later tonight. Thanks for your help.
