Activity Forums DaVinci Resolve Correctly archiving Projects?
  • Correctly archiving Projects?
    Posted by Florian Gintenreiter on January 8, 2015 at 9:01 pm
    I have graded a feature-film last year. I worked on the grade way before editing was finished and picture-lock took a while, so I had all the camera-footage on my media drive so that I could swap or replace a shot easily if need be and believe me that need did arise.
    Now that the film has been released and final tweaks are done I wanted to archive the project off my main Raid to a backup location. There is no need for me to keep all the camera-footage that is not used in the cut, because it’s backed-up elsewere but I want to archive all the media that’s in the cut to be able to quickly change something should the need arise.
    In order to do that I followed the steps outlined in the DaVinci 11 Manual (November 2014 Edition) on page 381.
    – Consolidated all the clips used in the Timeline to an external location, preserving the directory-structure. (I consolidated the whole source clips and did not trim them.)
    – Saved the Project under a new File-Name
    – Removed all the clips from the media pool
    – Right-clicked the sequence in the Edit/Timelines view and did Import > Additional Clips With Tight Filename Match
    – The timeline was now referring the the consolidated files at the backup-location, but all the grades were removed from the timeline.
    I solved that bay using color-trace and used the timeline still pointing to the original media-files as a source and thus was able to put back all the grades on my timeline pointing to the archived media, but I doubt that was the correct way of doing this. Had I not saved a copy of the project before I removed all the clips from the timeline, I would have lost my grades for good.
    It seems removing the clips from the media-pool also removed their grades even though the timeline was still in the project.
    How do I correctly do what I did in the future?
    cheers
    Florian
    ________________________________________
    Director of Photography, Director, Editor
    Vienna, Austria
    Sascha Haber replied 11 years, 8 months ago 5 Members · 4 Replies
  • Margus Voll
    January 8, 2015 at 9:26 pm
    If you have same names and tc in consolidated files then trimmed files should connect correctly without colortrace.
    Margus
    https://iconstudios.eu
    Resolve 11
    BMC 2,5k
  • Glenn Sakatch
    January 9, 2015 at 3:18 pm
    If you are keeping all the source files used…not trimming anyway, I would just export the final version of your project.
    If you want to rebuild it, import that project, select the clips in your media pool, and do a “change source folder” to the location of your consolidated clips.
    Same as if you had to switch hard drives at some point or transfer the project to another system.
    Glenn
  • Clark Bierbaum
    January 10, 2015 at 1:05 am
    Can’t say enough good about: https://www.niwa.nu/resolve-collect/ if on Mac. Great tool!
  • Sascha Haber
    January 10, 2015 at 12:45 pm
    The link is not working
    You will find it here :
    https://itunes.apple.com/dk/app/resolve-collect/id668433918?mt=12
    A slice of color…
    Resolve 11.1.2 – Smoke 2015 – Sapphire 8
    Colorist / VFX Guru / Aerial footage nerd
    https://vimeo.com/saschahaber
